new stf build - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 13 (permalink) Old 07-30-2016, 09:24 PM Thread Starter
new stf build
so I live in pa my names darian I have a silver mazda 3 sedan with options
as I spend another 45n min typing this up cus I time out -.- I hope you enjoy
ENGINE MODS:
AEM intake
corksport exhaust with test pipe
ov 93 bench tune
Damond rmm
Damond pmm
AWR 88 duro trans mount
tb ground (that's a mod right?)
Vibrant performance 4-2-1 ceramic coated headers
3inch vibrant high flow cat ceramic coated
SUSPENSION
8k 12k bc br with camber plates valved for spring rates
with adjustable front endlinks
Hotchkiss rsb
poly filled trailing arm bushings
Whiteline rear adjustable endlinks
Dominant engineering camber arms
TRANSMISSION :
twm short shifter with bushing
extender and phantom weighted knob
BRAKES:
speed 3 brake swap
dot approved techna-fit brake lines
hps pads
centric blank rotors
MISC:
08 interior swap bezels and panels
08 tail light swap
mazdaspeed3 seats n corbeau front seat
cooling panel
custom headlights blacked out with cutoff mod and painted cutoffs
interior lighting
Fog delete
cs stubby attenna
Mobil 1full synthetic 5w-30
TO DO LIST:
battery relocation
catch can setup - done
new clutch resurface flywheel (if possible)
full ground kit and big 3 -done
afr guage- not doing aorn
Oil pressure -done
tints prolly not rn
Shave wieght
3.2s is offline
post #2 of 13 (permalink) Old 08-09-2016, 08:40 AM
Nice setup!
funnyone is offline
post #3 of 13 (permalink) Old 08-11-2016, 03:03 PM Thread Starter
Thanks, I relied I can't do a vtcs delete luckily it was on my second manifold
3.2s is offline
post #4 of 13 (permalink) Old 11-24-2016, 04:04 PM Thread Starter
ENGINE MODS:
AEM intake
ov 93 bench tune
jbr 80 duro rmm
topspeed pmm
speed 3 cs insert
tb ground painted vc(that's a mod right?)
SUSPENSION
mazdaspeed3 rsb
new replacement bushing non poly
just moog
cs camber arms
cs front strut bar with custom setup for ingalls torque damper
TRANSMISSION :
BRAKES:
speed 3 brake swap
hps pads
MISC:
08 tail light swap
mazdaspeed3 seats
cooling panel
mtx jackhammer 12 inch with jbl 770 amp with jbl speakers
interior lighting
cs fogs
cs stubby attenna
Valvoline full synthetic 5w-30
TO DO LIST:
battery relocation
vtcs delete
catch can setup
speed 3 vc
sure tmm and pmm
plastic dip the cars white (due to the rust)
vynl door sills (rust again)
afr guage
ail pressure
spc camber arms
tint
Balance shafts delete
some other here there things. I'm proly missing some stupid things
Trying to figure how to cut weight n if I can infant delete ac
So since it's been awhile I've changed alot if things from damond motor mounts in the rear n passenger side I got ahold of d.e camber arms I went to a Hotchkiss rsb deleted fog lights took out the sub. The corksport bar is going no more torque damper, n will be updated
3.2s is offline
post #5 of 13 (permalink) Old 11-26-2016, 07:57 PM Thread Starter
So my corbeau seats showed up today! N some how cracked my oil filter canister n went all over my shop floor after start up, the autox season over n I did really well, I got 2nd in 2 regions due to lack of events, I contacted 18 racing placed n order for 15x7.5 rota slips, currently trying to fit wilwood brakes for the speed 3 but run 300 mm rotors, will see
3.2s is offline
post #6 of 13 (permalink) Old 11-28-2016, 10:45 PM Thread Starter
Wink
So fast brakes contacted. N told me they could definitely make these fit on the slips
3.2s is offline
post #7 of 13 (permalink) Old 11-28-2016, 10:48 PM Thread Starter
Some pictures
3.2s is offline
post #8 of 13 (permalink) Old 01-09-2017, 10:07 PM Thread Starter
Well I guess more updated got corbeau racing seats
Ebc yellowstuff
Going back to standard brakes
Innovate oil temp n pressure guage
Whiteline adjustable rear Endlinks
AWR tmm 88 duro on its way
If anyone can find me a set of vibrant headers IL love you you in a gay way forever
3.2s is offline
post #9 of 13 (permalink) Old 02-12-2017, 05:57 PM Thread Starter
Updated
I got my new trans mount in catch cans installed
Found a set of vibrant headers n ceramic coated them oil pressure guage is almost installed, my slips have also arrived
3.2s is offline
post #10 of 13 (permalink) Old 02-14-2017, 09:02 AM
petes's Avatar
Did you use a sandwich plate for the oil pressure/temp sensor or did you re-use the OEM sensor location?
My first Mazda, a 2008 Mazda 3 Hatchback, 2000cc, manual. Let the fun begin!
petes is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Mazda3 Media > Multimedia / Build Threads
STF build Thread Adam3s Autocross, Track, and Dyno Results 826 10-22-2016 10:16 PM
Kenlilley04's STF Build Thread Kenlilley04 Autocross, Track, and Dyno Results 85 07-30-2016 10:18 PM
Hstreet -> STF build k3v Autocross, Track, and Dyno Results 74 05-24-2016 11:21 AM
