2008 Mazdaspeed3 Headlight question - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 23 (permalink) Old 10-17-2010, 03:10 PM Thread Starter
due to idiot drivers in the rain, my driverside headlight was crushed . Now my problem is the dealer wants $460 for a new headlight, and when i look online i see headlights everywhere for the sedan models but nothing for MS3 hatchback, are they interchangable? with little to no modification or if they are not does anyone know where i can get a MS3 headlight that wont kill my wallet, ebay has a ton but all for sedan, even tho they say compatibitle with mazdaspeed 3, the seller told me only mazdaspeed3 sedan(dumba$$ they dont have mazdaspeed3 sedans)
thanks
chris
Janks85 is offline
post #2 of 23 (permalink) Old 10-17-2010, 04:07 PM
Re: 2008 Mazdaspeed3 Headlight question
MZ3 Hatch and MS3 use the same headlights.
There are headlights sold on this forum left and right. Look around.
say chi sin lo is offline
post #3 of 23 (permalink) Old 10-17-2010, 04:12 PM
^^ agree, post a Want to buy thread and you might get lucky.
|Bc Coil-Overs|SPC Rear Camber Kit|8k HID Lows and Fogs| 7k Angel Eyes| 17x7.5 Speedy Lite-Fin Wrapped in 225/45/17 General Exclaim UHP| Custom Interior- Painted pillars, Door panels two Toned Black and Red Suede, Black Leather Headliner|
Carowen is offline
post #4 of 23 (permalink) Old 10-17-2010, 04:49 PM Thread Starter
Thanks Guys. Say Chi Sin Lo: that helped me out because i just found 1 for a mz3 hatchback, but was not sure if it was the same as ms3 hatch. very much appreciated from both of you
Janks85 is offline
post #5 of 23 (permalink) Old 10-17-2010, 05:37 PM
ASK whether or not that headlight is for halogen or OEM HID.
The back end of them are different, along with the projectors.
post #6 of 23 (permalink) Old 10-17-2010, 07:29 PM Thread Starter
which do i need, the dealer will not give me a part number so im in the dark of what im looking for
Janks85 is offline
post #7 of 23 (permalink) Old 10-17-2010, 07:45 PM
icspots's Avatar
Sedan and hatch/MS3 headlights aren't compatible. Technically there are different p/n's for the regular Mz3 hatch and the MS3 but they work interchangeably.
If they quoted $460 then you must have halogens as the OEM HID housing is $800+ new from the dealer. To confirm look at the switch panel to the left of the steering wheel. You should have a dimmer dial, a TCS OFF switch. If that's all you have then you have halogen housings. If you have an additional dial that toggles between 0-4 then you have HIDs..
icspots is offline
post #8 of 23 (permalink) Old 10-17-2010, 07:51 PM Thread Starter
ya no 0-4 just dimmer and tcs..thank you everybody for your help i atleast now know what im looking for. I didnt know headlights could be so difficult until i am trying to deal with ebay sellers and auto parts places to get the right one
thanks chris
Janks85 is offline
post #9 of 23 (permalink) Old 11-03-2010, 01:51 AM
I'm on the same boat as the OP. Though I have condensation in the driver's side headlight (they are modded).
I have an 09 MS3 Sport with no OEM HID. I saw some deals on eBay for the OEM HID assembly with no bulbs/ballasts for a decent price. Can I just bolt these in or do they require modification since it has the OEM HID parts on them? I already have an aftermarket HID set-up but they are not D2S (mine are H7).
COBB l CP-E l HKS l BC l STREET UNIT l XENITH XENONS l TRS l WFC #728
shortwave is offline
post #10 of 23 (permalink) Old 11-03-2010, 12:15 PM
icspots's Avatar
[quote author=shortwave link=topic=181002.msg3848148#msg3848148 date=1288763465]
The housing itself will bolt right on in place of the halogen one. The projector is designed for a D2S lamp, so you'll need to get D2S lamps to plug into your ballasts. If the headlights come with the leveling motors you can retrofit the wiring to hook those up (obviously you'd need the leveling switch as well).
If you're doing this I'd highly recommend swapping in a clear lens to clean up the cutoff before installation. Also if you want the color flicker you can add washers at the same time.
icspots is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > 2004-2009 Exterior Modifications
