How-to Guide: Front Bumper Removal (Sedan Mz3S bumper) - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 64 (permalink) Old 03-10-2006, 12:08 AM Thread Starter
Send a message via Yahoo to sok07
As requested from an eariler post.....here's the front bumper removal walkthrough. There wasn't a "Technical / how-to" child board for the Exterior mod section of the forum, so I hope that this will become either a sticky post or spur the creation for a new child board for this section. Anyhow, I hope you guys appreciate all the how-to's/walkthroughs that I've written so far. As always, donations for my time & effort are always welcome
[size=8pt]Use & Disclaimer:
  • Please do not cross-post this how-to guide / walkthrough and its content (pictures, textual information, etc) to any other forums or boards outside of Mazda3forums.com without first requesting & gaining my permission.
  • This short how-to should not be used as an all-encompassing walkthrough. It is simply a brief description of my procedures for removal & installation, and I am not responsible for any damages or injuries that may result.
[/list][/size]
[size=14pt]
How-To Guide: Front Bumper removal/install for the Mazda3s Sedan[/size]
Tools needed
  • Ratchet w/ 8mm socket & 1-2" extension
  • phillips screwdriver
______________________________________________
1.) Using the ratchet, 8mm socket and extension ... Remove the (11; 3 left portion, 5 center portion, 3 right portion of the lower splashguard) 8mm bolts holding the splash guard sections to the bottom of the bumper. The picture below shows only 7, but there are 11 to remove.
2.) Using a phillips screwdriver ... Go to the front wheelwells and remove the (4; 2 per side) fore plastic clips holding the splashguard. Turn the wheels left/right to gain the necessary clearance.
3.) While still in the wheelwell area, gently pull the plastic splashguard away from the bumper. Then using a phillips screwdriver or ratchet w/ 8mm socket & extension ... Remove the (2; 1 per side) 8mm bolts that hold the rearmost top corner of the bumper to the fender. Again, turn the wheels left/right to gain the necessary clearance.
4.) Using a phillips screwdriver ... Remove the (2) plastic clips and the (2) metal screws on the top of the bumper near the front grille area.
5.) Next, go down and unclip the foglight wire from the bumper and remove the foglight bulb / socket from the foglight.
[size=8pt]Sorry...no picture for this step. Should be self-explanatory[/size]
6.) After you've removed all of the mounting hardware, there are only clips from this point on. Go back to both side portions of the bumper and pull gently outwards, the bumper should unclip from the fender.
7.) Then go to the front of the bumper and look down the bumper/ radiator gap behind the grille ... you should see (2) large black rectangluar-shaped plastic hook clips that hold the bumper in place to the bumper reinforcement frame/styrofoam pad, unclip it.
8.) After doing all of the above steps *carefully* the bumper should be free. So just slighlty tilt it and pull it towards you. Make sure you lay a towel / blanket / carpet down and place the bumper down on that so you won't scratch the paint.
For installation / re-installation of the front bumper, just simply work backwards.
[/list][/size]
2009 Mazdaspeed3
Cobb AP | Cobb DP | Cobb bpv | Tubular exMani | PTP hpfp internals | RPMC turbo inlet | 3.5" core ETS TMIC | EliteEngineering PCV catchcan | CPE Trans/Pass MM | TWM SS | SU RMM | Cobb R anti-swaybar | H&R coilovers | Porsche997 bixenon projector | bosch h3 projector foglights | ...etc, etc
2003 Toyota MR2 spyder
1973 MGB GT
sok07 is offline
post #2 of 64 (permalink) Old 03-11-2006, 01:47 PM
Re: How-to Guide: Front Bumper Removal (Sedan Mz3S bumper)
Thanks Sok! I've been waiting for one of these for so long. Someone sticky this.
Cero21 is offline
post #3 of 64 (permalink) Old 03-12-2006, 11:35 PM
Send a message via AIM to quiksilverx181
thanks man! Ill be doing this on tuesday, my intake will be here by then and i should have some time tuesday
I now own a 2008 350z Base MT
quiksilverx181 is offline
post #4 of 64 (permalink) Old 03-13-2006, 06:05 PM
Thanks for the guide, you are awesome
04 GT w/GFX, 5 spd, Titanium Grey....****SOLD****
07 STI
aznpryd is offline
post #5 of 64 (permalink) Old 03-13-2006, 06:14 PM
Were you just doing this to do it? Or was there a purpose behind just showing us how? Just curious
pinchel is offline
post #6 of 64 (permalink) Old 03-13-2006, 08:24 PM Thread Starter
I was playing around w/ the HID projectors / bulbs. Specifically to get back there and replace the D2s bulbs, but inorder to do that the headlight housing has to be removed from the vehicle = remove front bumper.
2009 Mazdaspeed3
1973 MGB GT
sok07 is offline
post #7 of 64 (permalink) Old 03-13-2006, 10:13 PM
OH geez...I doub't I'll be doing that mod. I'll call you if I change my mind. 8)
pinchel is offline
post #8 of 64 (permalink) Old 03-13-2006, 10:23 PM
[quote author=Pinchel link=topic=41782.msg616531#msg616531 date=1142288063]
Haha I was thinking the same thing.....that maybe he was writing for the haynes manual company or something.
Progress || MB Motorsport Drifters 18x7.5 +45
225/40R18 Kumho Ecsta 711's || 35% Tint
deluxe is offline
post #9 of 64 (permalink) Old 03-14-2006, 12:02 AM Thread Starter
Isn't obvious what I do as my day job. I'm an engineer. So naturally I like to tinker, design, fabricate, modify, take thing apart & put them back together....and my biggest flaw is I "see a good design and still have to change it".
2009 Mazdaspeed3
1973 MGB GT
sok07 is offline
post #10 of 64 (permalink) Old 03-14-2006, 12:50 AM
Why hasnt someone said STICKY!!! yet?
Ask a stupid question, get a stupid answer
BigTrucker is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Visual / Audio > 2004-2009 Exterior Modifications
