6 speed NON-Mazdaspeed transmission swap? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 21 (permalink) Old 09-23-2012, 05:36 PM Thread Starter
Has anyone tried to swap the non-Mazdaspeed 6 speed transmissions onto the 2.0 or 2.3L engines? Most everything I'm finding while searching around the forum seems to be about putting the MS3 trans into an 04-09 car, not the new 10+ 6-speed that you can get in the MZ3 and MZ5. Are the bellhousing (or whatever you call the interface between engine and transmission) the same?
phunky.buddha is offline
post #2 of 21 (permalink) Old 09-23-2012, 09:07 PM
Banned
they should be the same bell housing and it should work. pretty sure all MZR blocks have identical designs and bolt holes etc
Orangevirus1 is offline
post #3 of 21 (permalink) Old 09-24-2012, 03:31 PM
Moderate your face
dugger_8's Avatar
It would be how the transmission mount is placed that would need research. It might be slightly different on the 10+ from the 04-09.
And shifter cable length, and the shifter as well. They might be different between the gen 1 and gen 2 bodies.
dugger_8 is offline
post #4 of 21 (permalink) Old 11-19-2013, 11:15 AM
Anyone tried this yet? I'm close to end of life on my 5 speed and would love the extra gear.
DanM5 is offline
post #5 of 21 (permalink) Old 11-19-2013, 11:30 AM
Administrator
I've never seen anyone do it, I don't know why anyone would need to do it.
A lot of people make a big deal about how high RPMs you sit on the highway, well that's how the car is made, that's where it's supposed to be (welcome to low HP cars).
By adding in another gear.. it doesn't change that, you'll be at a very similar RPM, you'll jut be in another useless gear.
Don't count on it working, mount points changed.
An additional gear makes no difference, it just means more can go wrong with it.
post #6 of 21 (permalink) Old 11-19-2013, 12:47 PM
okellyr's Avatar
A little negative lol but I agree ... Mount points will be a pain and the gearing may actually have a negative impact + ur adding some weight .... Idk about the mz6 6speed but the ms3 6er is waaaayyyyy bigger and much heavier ( I can pick up a stock transmission and carry it no problems but a ms3 one takes 2 guys and it's heavy for both )
Boosted baby....
BOOSTED
okellyr is offline
post #7 of 21 (permalink) Old 11-19-2013, 02:58 PM
If the mount points changes then its definitely out of the question. I still would like to get lower revs on the highway. My other cars have similar weight to power ratio but turn ~2K @ 70mph the Mazda3 spins ~3K. In my opinion Mazda engineers missed the mark on gearing and if I can fix I will, just might be stuck with taller tires instead of a better spread of transmission ratios.
DanM5 is offline
post #8 of 21 (permalink) Old 11-19-2013, 03:16 PM
Administrator
There's nothing wrong with being at higher revs, if you're any lower it's probably going to end up damaging the internals over the length of the vehicle more than a higher rev range.
70mph in a first generation manual in 5th is indeed 3,104 RPM
70mph with a second generation manual in 6th is 2,200 RPM
While yes it is lower, the 2.3L does not create sufficient torque to get the great MPG it already gets.
by swapping transmission sure you can get a lower RPM, but at the cost of a harder working, less MPG engine.
In basic terms.. you're bogging the engine down for no reason.
If noise is the issue, there are plenty noise cancelling products on the market that can and will certainly alleviate noise.
post #9 of 21 (permalink) Old 11-19-2013, 03:20 PM
philrab's Avatar
As an example, my first gen Miata used to turn 4,000 rpm at 70. Got the fuel economy it was supposed to, and engine wear was what it should be for the miles.
Same issue exists in both cases; the engine made such paltry torque at such high RPMs, it cruises at higher rpm. I don't see an issue with it either way.
philrab is offline
post #10 of 21 (permalink) Old 11-20-2013, 01:45 AM
6th gear is nice when you live in an area where normal traffic flow is 80mph...
to each his own.
it should fit fine. just like the ms3 swap, you need to check the axles, flywheel, clutch, shifter cables...
the mount is the same. they just changed the way the tripod and frame side mount are connected, still a single bolt but also added a stud to help stop twisting.
verto is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Technical / Model / Performance > Powertrain for 2010-2013 > Modifications
LinkBack to this Thread: http://www.mazda3forums.com/671-modifications/398275-6-speed-non-mazdaspeed-transmission-swap.html
Modifications [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-12-2015 01:49 AM
Automatic Transmission swap to 5 speed Stiki Ride Modifications 15 02-05-2013 12:48 AM
MazdaSpeed 6sp Transmission Swap (upgrade) 5l1mm Modifications 2 07-15-2011 01:34 AM
Transmission Swap ? *Angel-Of-Darknes* Modifications 5 10-18-2006 11:31 PM
