Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 06-17-2017, 02:43 AM Thread Starter
I am going to flush my 5 speed A/T with Amsoil and I bought 9 quarts. Question, can I use 9 quarts of the cheapest tranny fluid at Walmart to make sure all old fluid is out? Thinking of getting this to flush with: https://www.walmart.com/ip/Super-Tec...Fluid/20573820
Just wanted to make sure old fluid is out and Amsoil is too expensive to only use to flush out old fluid.
2010 Mazda3 Sedan Black Mica
2.0L MZR Auto
beavis87 is offline
post #2 of 5 (permalink) Old 06-17-2017, 04:10 AM
MurderMazda's Avatar
I personally would'nt do it, Certain fluids are fortified for different clutch materials and will act differently. Your talking about the main driveline of your car here and dont wanna risk anything which is why you wanna use Amsoil right? That being said take some advice from someone who's been in your shoes. I was battling multiple trans leaks a few years ago. Did the filter and pan gasket along with new output shaft seals with mazda FNR5 fluid. One week after this the brand new output shaft seal was leaking, I tapped it in too far the first time. Bought another then bought more fluid from mazda and refilled. Good for a month then the worst leak of all.....input pump/torque converter bushing and seal gone. Dropped the trans, removed old seal and bushing and installed new bushing and seal and reinstalled the trans. Now keep in mind after every problem I had with leaks and shift solenoids I alway bought new fresh fluid from mazda so essentially the transmission was thoroughly flushed and clean. After all of this the last time I refilled the transmission I like you, used Amsoil ATF. The parts manager gave me a discount on the mazda Type MV or M5 ATF however you wanna call it so when I bought half a case of fluid he knocked off a few bucks and gave me the fluid almost at cost. Play it safe and flush it with oem fluid then go with Amsoil.
MurderMazda is offline
post #3 of 5 (permalink) Old 06-17-2017, 12:53 PM Thread Starter
Thing is, is that Mazda Type MV and Ford FNR5 are expensive as well, not Amsoil expensive but enough not to want to flush with it. I may just use Valvoline MaxLife.
2.0L MZR Auto
beavis87 is offline
post #4 of 5 (permalink) Old 06-17-2017, 01:48 PM
At work we have a BG fluid exchanger it requires 16qt. of fluid to do a proper exchange. If you don't have access to a machine like this then the best thing to do is to drain, refill, run, and repeat until the fluid color is good. No matter what you do you are going to end up with some of the old or cheaper fluid left behind.
post #5 of 5 (permalink) Old 06-25-2017, 02:52 PM
I've also understood that because of the the pressures and such, sometimes the flushes can cause more issues than they solve. I've always been advised that a simple drain and fill is the better option.
thzpcs is offline
LinkBack to this Thread: http://www.mazda3forums.com/667-powertrain-2010-2013/748826-auto-transmission-flush.html
Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 05:34 PM
Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 03:55 PM
Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 03:36 PM
Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 01:06 PM
Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 05:33 AM
Auto transmission flush - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 12:05 AM
New member question about 2016 Fusion 6F35 Transmission Fluid Level DLJR Introductions 0 06-11-2017 09:26 PM
Auto Transmission Plug Washer diexodos Introductions 1 04-23-2017 08:51 AM
2012 Mazda3 Automatic and transmission flush Brittany Nichole Introductions 13 04-09-2017 06:09 PM
2007 Mazda 3 auto transmission Fineapple Powertrain 2004-2009 Mazda3 7 01-09-2017 10:38 AM
HELP HELP HELP AUTO TRANSMISSION SWAP TO AUTO arsalan500 Modifications 0 11-28-2016 12:31 AM
