Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 8 (permalink) Old 06-15-2017, 12:07 PM Thread Starter
Just wondering if you peoples thoughts on using seafoam through the vacuum line into the intake manifold for cleaning at all? My 2010 mazda 3 sport just turned 115,000 miles and still runs like a champ. I've never done it to the car and I am still getting about 400-430 miles on a tank of gas. Just wondering your thoughts? Thanks.
spaniel1287 is offline
post #2 of 8 (permalink) Old 06-15-2017, 03:18 PM
I've done it and it works pretty good. Pro-tip: Go to the hardware store and pick up some poly tubing, a needle valve, a tubing "T", and a conical tubing adapter. The conical adapter will assure a tight fit to the vacuum line, the "T"(for airflow) and the needle valve allows you to control the flow rate of the seafoam(or insert your preferred fuel treatment), so you won't accidentally drown out the engine. You want a nice low flow rate.
It's basically a DIY version of the kit they use in shops to do this procedure, although you will have to play with the valve a bit to find the ideal flow rate.
Dalton63841 is offline
post #3 of 8 (permalink) Old 06-15-2017, 03:28 PM Thread Starter
Thank you for response. I did this about 10 years ago to my eagle talon turbo and she smoked like a son of gun. I was planning on doing this seafoam treatment (not in the oil, although a lot of people do it), and then drive about 50 miles and then replace spark plugs and do an oil change. I don't think much can go wrong doing this right? Any picture of which vacuum line to send in the seafoam through?
post #4 of 8 (permalink) Old 06-15-2017, 03:37 PM
The shop I worked at used the big fat line that connects to the brake booster. The white smoke is actually normal while you are doing the fuel treatment, and for a few minutes after.
EDIT: I'm not sure what the can says, but you only want to run about a third of a can through the vacuum line. I usually poor the rest in the tank with a full(or close to) tank of gas.
post #5 of 8 (permalink) Old 06-15-2017, 04:25 PM Thread Starter
Yes, I've seen peoplewho did this and then their car threw a CEL. The only thing I can think of would be the O2 sensors maybe through the exhaust? I dunno, I guess I could alwasy opt to not do this because my car runs perfect as it is and if it isnt broke don't fix haha. We will see.
post #6 of 8 (permalink) Old 06-16-2017, 04:47 AM
The CEL usually happens when the liquid is sucked in too quick. I'm guessing it doesn't get burned completely and then the O2 sensor freaks. That's why the very slow flow rate is necessary.
post #7 of 8 (permalink) Old 06-19-2017, 11:46 AM
I'll have to remember this for the future, thanks!
CanadaX21 is offline
post #8 of 8 (permalink) Old 06-25-2017, 02:53 PM
It also will usually cause the engine to chug and misfire, which also freaks the ECU out.
thzpcs is offline
LinkBack to this Thread: http://www.mazda3forums.com/667-powertrain-2010-2013/748714-do-you-guys-use-seafoam-vacuum-line.html
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 05:34 PM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-20-2017 09:59 AM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 05:52 AM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 05:22 AM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 02:18 AM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 11:49 PM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 11:38 PM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 11:31 PM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 10:22 PM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 10:05 PM
Do you guys use seafoam in vacuum line? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-15-2017 05:27 PM
hello guys. bjmix21 Introductions 0 01-03-2017 09:26 AM
Good morning guys tcdos Introductions 1 10-12-2016 01:47 PM
