I have an '04 3 which has been intermittently having issues with the instrument panel not going to "night time mode" when I turn the headlights on. I've discovered that this is probably connected to the parking lights and tail lights. I checked to see if either the parking lights or tail lights were having troubles, and they are not lighting up.
I checked the appropriate fuses, so my question is - is this more than likely a problem with the switch on the steering column, or a problem with a relay, which I understand means a new body control module (under glove box).
Is there a way to test the switch? If I replace the BCM, which I have located with correct part number, does the dealer have to touch it, or is it plug and play if I get the right one?
Any help is appreciated.
Thanks,
Brawndo
Thanks,
Brawndo
