18x9.5 wheels on Mazdaspeed 3 (2008.5)? - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum
post #21 of 34 (permalink) Old 01-18-2012, 11:21 PM
Re: 18x9.5 wheels on Mazdaspeed 3 (2008.5)?
I have 18x9.5 +35 so you should be fine
Sent from my Desire HD using Tapatalk
kradios is offline
post #22 of 34 (permalink) Old 01-19-2012, 03:06 AM
Send a message via AIM to lax22pearl
[quote author=kurupt link=topic=202396.msg4175354#msg4175354 date=1326937423]
[quote author=lax22pearl link=topic=202396.msg4175351#msg4175351 date=1326936824]
roll, 3mm spacer to clear strut, and around -3* camber should do the trick. and yeah will look ridiculous at stock height or even just lowered on springs. oh and i run a 215/35/18 on my 18x9.5
Thanks, that's really helpful to know! What offset are your wheels? And wouldn't the spacers make the wheel stick out even more than needed?
front is 18x9.5 +22 rear is -3. and yes but you may need it to clear strut. as stated above i know a +35 will clear but idk about a +38. thats why a 3mm spacer will do the job perfectly
lax22pearl is offline
post #23 of 34 (permalink) Old 01-19-2012, 12:57 PM
exentix's Avatar
just a thought.. you are talking about clearing the strut, but lax, arent you on coils? hes on stock suspension. ive heard the stock struts are way beefier than coils. might need a bigger spacer to clear then correct?
JAMES BARONE RACING
jbr stuff, cp-e catted dp, autotech cdfp internals, cobb ap, cobb xle bpv, grimmspeed ecbs, STRATIFIED TUNE in progress, enkei evo 6, continental dw, 35% tint
exentix is offline
post #24 of 34 (permalink) Old 01-19-2012, 03:08 PM Thread Starter
[quote author=exentix link=topic=202396.msg4175634#msg4175634 date=1326992249]
^ that's true that im on stock but when i drop, ill be on coils also. or are you worrying that before i drop, it will be a problem?
kurupt is offline
post #25 of 34 (permalink) Old 01-19-2012, 04:07 PM
Send a message via AIM to a-sher
Drop first, wheels second.
a-sher is offline
post #26 of 34 (permalink) Old 01-19-2012, 07:27 PM
Curious what coilovers you run that 9.5 +38 wont even clear. I fit a 17x9 +48 on and it clears the strut by a credit card. That would mean a 9.5 +40 would fit the same if not a little more room so 9.5 +38 should clear pretty easy. You need a spacer ontop of that though?
2010 Mazda3i Touring - Liquid Silver
dnick454 is offline
post #27 of 34 (permalink) Old 01-19-2012, 08:11 PM
sdemo45's Avatar
tire size matters. I couldn't clear 8.5 +48 with 245s.
sdemo45 is offline
post #28 of 34 (permalink) Old 01-19-2012, 08:30 PM
[quote author=dnick454 link=topic=202396.msg4175831#msg4175831 date=1327015658]
not me but another guy with BCs and 18x9.5 +35 says it is super close. idk exactly how close casinos it's not my car but going off of what I've heard/read
post #29 of 34 (permalink) Old 01-19-2012, 09:45 PM
Re: Re: 18x9.5 wheels on Mazdaspeed 3 (2008.5)?
[quote author=lax22pearl link=topic=202396.msg4175849#msg4175849 date=1327019406]
That was me, and yes its very close, I had to use a 215/40 tire, a 225 wouldn't fit.
kradios is offline
post #30 of 34 (permalink) Old 01-23-2012, 07:04 PM Thread Starter
so how dangerous is it to drive a 215/40/18 stretched on a 18x9.5? i do like stretched tires but i dont want them to be so thin that it can easily pop if u hit a pothole or nail.. should i be worried much and consider going to 225?
and if i do choose 225 over 215, will it be a problem to put 225/40/18 on the MS3 stock rims (normally wears 215/45/18)?
kurupt is offline
LinkBack to this Thread: http://www.mazda3forums.com/63-wheels-tires/392298-18x9-5-wheels-mazdaspeed-3-2008-5-a.html
Wheels / Tires [Archive] - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-18-2016 08:21 PM
