Can i use 14" or 15" rims on my 2010 mazda 3 hatch? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 11 (permalink) Old 07-02-2011, 07:59 AM Thread Starter
boss500's Avatar
Looking to get 14" or 15" rims to run in the winter. What is the tire size conversion for both? i'm running 205/55/16 right now
2010 Mazda 3 Sport l Corksport cat-back exhaust l Corksport SRI l Corksport cold air box l TWM short shifter l Hurst T shifter l Mazdaspeed pedals l 16" DR9's l blue interior lighting kit l Mazdaspeed spoiler l carbon fibre stub antenna l Bayson R body lips l stainless MZ3 scuff plates l Custom ram air
boss500 is offline
post #2 of 11 (permalink) Old 07-02-2011, 09:11 AM
mazdaboy2.3's Avatar
Re: Can i use 14" or 15" rims on my 2010 mazda 3 hatch?
pretty sure 16 is as small as you can go to clear the caliper.
anyone else?
I tried Autocross once, and won....I think i'm gonna like this.
Build thread:
mazdaboy2.3 is offline
post #3 of 11 (permalink) Old 07-02-2011, 09:36 AM
Administrator
yeah, 16 is the smallest.
2.0 sedans MAY be able to fit a 15 but the thought scares me.
a Speed 3 can fit a 16, but dangerously.
post #4 of 11 (permalink) Old 07-02-2011, 10:00 AM
The hatchback is available with the 2.0L here in Canada. If the GX hatch uses the same brakes as the 2.0L sedan then you should be able to use 15" wheels. Maybe someone at the dealer parts/service dept would know for sure?
You are not going to get 14" wheels to fit - even the "small" brakes on the 2.0L sedan are too big for that.
balding geezer is offline
post #5 of 11 (permalink) Old 07-02-2011, 11:07 AM
looks like you have the 'sport' hatch, if that's the same as the US (larger brakes) then 16" is the minimum. even those look scary close to the calipers.
MattA is offline
post #6 of 11 (permalink) Old 07-02-2011, 02:40 PM
+1, pretty sure that some of the first gen 2.0 sedans came with 15" steelies, but you will never get a 14".
2K10 Mazda 3
[Simota CBII] | [FI Grounding Kit] | [DDM Tuning 6000k Low/PIAA Intense White High] | [Redline Goods Shiftboot] | [PC'd Stock Wheels] | [JBR Solid Shifter Bushings] | [Blacked Emblems/Side Markers/Plates] | [Redline MT-90] | [15% Tint] | [Timing Advance] | [Parking Light Delete] | [Weathertech Floor Mats] | [Corksport Inserts] | [Corksport LED's] | [Moddiction Anvil]
Horrorscope is offline
post #7 of 11 (permalink) Old 07-02-2011, 03:19 PM Thread Starter
boss500's Avatar
ok thanks guys. i will check caliber and see if 15" will work
boss500 is offline
post #8 of 11 (permalink) Old 07-02-2011, 10:48 PM
Administrator
Scary....
One guy I came across on here was running 16s on a speed 3 over winter and he said the calipers were so close it knocked off the balance weights that were on the wheel. Just get 16s, don't be stupid and dangerous.
Surely someone will sell you 2.0 16s for a lot cheaper you can get some 15s and will be better as far as weight and looks, just saying.
post #9 of 11 (permalink) Old 07-03-2011, 08:11 AM
I haven't tried it yet, but a cheap way to go would be to get a set of 16" wheels from a Ford Probe or Mazda MS6. They have the same bolt pattern (5x114.3) as does the Mazda3. I'm not certain if the wheels will fit, though. I'm going to research this some since I have access to a Probe, but won't know the answer till probably next weekend at the earliest.
Stapleface is offline
post #10 of 11 (permalink) Old 07-03-2011, 10:16 AM Thread Starter
boss500's Avatar
was going to try 14 or 15 cause winters tires cheaper then 16's. winter tires on 16's here start around $140
boss500 is offline
