Front tires wearing fast on outside only. Why? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 12 (permalink) Old 11-19-2009, 12:39 PM Thread Starter
I have a 2009 Mazda 3 Hatchback with just over 7,000 miles and I have noticed both of the front tires are wearing excessively on the outside edge. At 4,700 miles I had the tires rotated and the tires that were on the front show considerable outside edge wear. 2,300 miles later and the current front tires are showing the same thing. The tires are all at 35 psi and they are the stock Goodyear RSAs. I understand that these tires are crappy, but is this normal for these tires? I don't autocross or drive like a maniac, so this kind of wear is disappointing.
TheJMan41 is offline
post #2 of 12 (permalink) Old 11-19-2009, 12:41 PM
strato.blue.3's Avatar
Send a message via AIM to strato.blue.3 Send a message via Yahoo to strato.blue.3
Re: Front tires wearing fast on outside only. Why?
[quote author=TheJMan41 link=topic=161172.msg3423631#msg3423631 date=1258648789]
i see your in AZ how hawt is it there?
EPIC
Boosted Carb Build
strato.blue.3 is offline
post #3 of 12 (permalink) Old 11-19-2009, 01:01 PM
Might be an alignment issue.
g3ck0 is offline
post #4 of 12 (permalink) Old 11-19-2009, 01:07 PM
Moderator of donks
halo0's Avatar
Excessive wear on the outside edge usually indicates too much toe-in on the front. Assuming you bought it from a dealer take it back and tell them to fix it. It should be aligned properly from the factory.
halo0 is offline
post #5 of 12 (permalink) Old 11-19-2009, 01:10 PM
toe in, definitely your problem if underinflation is not.
Dealer will probably not pay for it, but you can always try.
H-Stock 3
rubyred3 is offline
post #6 of 12 (permalink) Old 11-19-2009, 01:13 PM
Send a message via AIM to Trubopower
Under 15000 miles they have to cover it
Trubopower is offline
post #7 of 12 (permalink) Old 11-19-2009, 01:14 PM
y would they have to cover it? You could have run your car into a curb and f'd up your alignment the day after you bought your car (not saying the OP did, just saying why they aren't really liable here).
H-Stock 3
rubyred3 is offline
post #8 of 12 (permalink) Old 11-19-2009, 01:29 PM
Outside of instances like obvious abuse alignment is covered by a 15k/6mo warranty, most cars are out from the factory due to transportation, also most of the time you can file a claim with the manufacturer for a reimbursment
post #9 of 12 (permalink) Old 11-19-2009, 05:18 PM Thread Starter
While the car is older than 6 months old, I guess I'll take it to the dealer and see if they can take a look at it. And no, I have not hit any curbs, I don't want any curb scuffs on those wheels! Anyway, thanks for the advice.
post #10 of 12 (permalink) Old 11-19-2009, 11:25 PM
Six
theykickedmeoffnasioc
Six's Avatar
over positive camber? :P
Six is offline
