04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By madmatt2024
post #1 of 8 (permalink) Old 06-14-2017, 02:13 AM Thread Starter
Is there an OEM rubber boot available for the front lower ball joint in the 04-08 MZ3 control arm?
There is one available for 10-13 MZ3s: G03034565
Does anyone know if it is the same size or not?
gwiffer is offline
post #2 of 8 (permalink) Old 06-14-2017, 06:49 AM
I have to ask: why would you only replace the boot? If your ball joint is worn out, replace the whole thing. If the ball joint *isn't* worn out, let it ride.
theblooms is offline
post #3 of 8 (permalink) Old 06-14-2017, 05:25 PM Thread Starter
The boot is cracking and is about to tear, but the ball joint itself is fine. A torn boot always leads to a worn ball joint from dirt/grit contamination. It's a question of a $10 boot vs $150 for the OEM lower control arm. I don't trust any aftermarket brands for critical suspension parts.
gwiffer is offline
post #4 of 8 (permalink) Old 06-14-2017, 08:21 PM
I think there's a good chance that'll have its own part number. Should be relatively easy to find. Have fUn getting dirty. FYI most techs would let the boot slide and just let the customer know that a control arm might be coming in the future. As far as suspension competent's I never go lowe than oem but lots of stuff is better or equal. By equal I mean the same manufacturer makes the oem and aftermarket part. Saved my girlfriend a couple hundred dollars by going denso from advance instead of denso from Honda. And usually a better warranty. Have fun, wear gloves
JavierV is offline
post #5 of 8 (permalink) Old 06-17-2017, 09:57 PM
Foolishness. A: The ball joint can be replaced independently of the control arm. B: Aftermarket suspension parts are fine and in some cases better than OE. Moog is a good example of this with their "Problem Solver" line. Stay away from their cheaper "R series" parts and you will be just fine.
theblooms likes this.
madmatt2024 is online now
post #6 of 8 (permalink) Old 06-18-2017, 11:53 PM
I've always had great luck with Moog. Good quality for sure.
post #7 of 8 (permalink) Old 06-22-2017, 01:30 PM Thread Starter
Moog only sells R-series control arms for the Mazda 3 and Rockauto only lists Mevotech and MAS for replacement ball joints. I don't know about you, but I'm not trusting these questionable parts for a lower ball joint.
OEM Mazda doesn't sell the ball joint separately.
gwiffer is offline
post #8 of 8 (permalink) Old 06-22-2017, 05:48 PM
What I would call questionable is no-name stuff from ebay. Mevotech is pretty huge in the automotive world, their parts are rebranded and sold under a number of different names including Raybestos. As with Moog I would stay away from their cheap stuff. They actually have an HD grade ball joint for your application which is a line I didn't even know they made. I don't have any experience with MAS though from the pictures their stuff looks decent. They might be the OE supplier for all I know given that their parts don't have grease fittings.
LinkBack to this Thread: http://www.mazda3forums.com/62-suspension-brakes/748690-04-08-mz3-front-lower-ball-joint-boot-replacement-oem.html
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 05:52 AM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 05:22 AM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 02:18 AM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-17-2017 02:16 AM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 10:22 PM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-16-2017 10:05 PM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-15-2017 04:52 AM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-15-2017 04:45 AM
04-08 MZ3 Front Lower Ball Joint Boot Replacement...OEM? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-14-2017 03:18 PM
2009 Mazda 5 Front lower control arms VancouverMark Suspension / Brakes 2 01-04-2017 11:15 AM
Driver side front lower control arm replacement problems beavis87 Suspension / Brakes 2 12-03-2016 12:49 AM
