2009 Mazda 5 Front lower control arms - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 3 (permalink) Old 01-03-2017, 05:47 PM Thread Starter
In an effort to fix the front end issues, I bought new front lower control arms and proceeded to remove and install new ones. The drivers side one came out and a new one went in with very little issue aside from having to remove the brake rotor for clearance and some issues getting the rear to bolts to line up properly. The passenger side has given me some grief though. The control arm wasn't connected when I tried to remove the brake rotor which resulted in some 'movement". Now when I go to reinstall the new control arm, the ball joint seems to be about 1" to far inboard to connect to the knuckle. Is it possible I knocked something out of alignment by banging on the rotor without the control arm connected? It looks like the alignment is out because if I put the steering wheel straight, the drivers side looks straight, but the passenger side appears slight turned. Is my next step to disconnect the axle in order to get some movement for the knuckle? I have confirmed I have all the right parts, but am at a bit of a loss. Any help would be appreciated.
Thanks in advance,
Mark
VancouverMark is offline
post #2 of 3 (permalink) Old 01-04-2017, 11:24 AM
Did you check to see if the axle popped out of the tranny a bit, as a result of you hitting the rotor?
2011 3i 2.0 A/T 93K miles (daughter's ride which I maintain)
m3iguy is offline
post #3 of 3 (permalink) Old 01-04-2017, 12:15 PM Thread Starter
Found the problem. The "tripod" joint had moved out of the housing from striking the rotor. Got it re-assembled last night and just need to get a new clamp for it. Hope to have it all back together tonight.
Thanks,
Mark
LinkBack to this Thread: http://www.mazda3forums.com/62-suspension-brakes/741017-2009-mazda-5-front-lower-control-arms.html
Suspension / Brakes [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-04-2017 04:46 PM
Driver side front lower control arm replacement problems beavis87 Suspension / Brakes 2 12-03-2016 01:49 AM
Mazda 3 2004: squeaking and creaking in front driver's seat krneki Mazda3 (Axela) 0 11-04-2016 02:56 PM
My Mazda speed3 front end conversion law0454 Introductions 0 10-16-2016 12:00 PM
WTB: 2012 Mazda 3 Bumper, Grille, & other front end parts lavigeboy27 Want to Buy | M3F 0 09-30-2016 05:08 PM
2011 Mazda 3i Cruise Control samilton27 Interior Modifications 0 08-27-2016 06:36 PM
