Cheap rear camber arms? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 2 (permalink) Old 12-18-2016, 05:17 AM Thread Starter
Took my car in for an alignment and they said they couldn't get left rear wheel within spec. -3.3 camber, actually increased -0.2. They told me I need new rear camber arms as is common with small mazdas. They quoted me $136 each plus $135 labor. Thought that was bit much so I went to rock auto and found these for $22.89: https://www.rockauto.com/en/moreinfo...928&cc=1444217
ULTRA-POWER MS40125
Is it too good to be true? Looking at other ones on there, they all look to be the same, so are the Dorman ones really worth $127 more?
MEVOTECH CMS40125 - $44.79
MAS CA85506 - $56.79
MEVOTECH GS40125 - $69.79
MOOG K100002 - $75.89
DORMAN 522674 - $149.89
2010 Mazda3 Sedan Black Mica
2.0L MZR Auto
beavis87 is offline
post #2 of 2 (permalink) Old 12-18-2016, 02:33 PM
SPC is the original maker of the camber arms so all the other ones you see are either copies or re-labels. The only difference is the quality of the bushings used in the arms, you can see the difference in the pictures. I bought some cheap ones off ebay and a two years later one of the bushings was shot. I ended up reusing the stock arms with Whiteline camber bushing to get it within spec. With the camber being that far out though I would check for damaged suspension parts, I couldn't even get mine to -3 with the Whiteline bushings!
Rear popping noise bpe383 Suspension / Brakes 4 11-19-2016 09:06 PM
Like new corksport rear motor mount deathspared For Sale | M3F 3 11-17-2016 09:08 PM
HELP WITH REAR COILOVER INSTALL Turbolag323 Suspension / Brakes 3 10-30-2016 03:26 PM
JBR Passenger & Rear Motor mount + Corksport Rear Sway Mazdabazda For Sale | M3F 4 10-29-2016 12:50 AM
Do I need adj. rear camber for new coilovers?? alex_rodriguezz Suspension / Brakes 0 09-29-2016 04:49 AM
