Brake noise in reverse - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 11-15-2016, 01:04 PM Thread Starter
OK, got an oddball one. This isn't a problem with my car, but with a 2007 Mada 3 that my significant other recently bought. She lives 800 miles from me, so I have not seen this problem in person and can't give much in the way of details but can ask her if need be.
This problem only happens if the car has been parked a while and has cooled-off, never when warm. What happens is that the brakes make noise when she's backing out of a parking space and turning at the same time. NO noise when moving forward, only reverse. And NO noise when the car has been warmed-up, only when it has sat for a while. And NO noise when she reverses in a straight line, only while turning and braking at the same time while in reverse.
Gotcher head wrapped around that list of symptoms? Any thoughts?
2013 i Grand Touring hatch- Dark Star
The Veg is offline
post #2 of 5 (permalink) Old 11-19-2016, 08:04 AM
Phames11's Avatar
My only guess is that the car has sat through some changes in humidity. So the rotors have some flash rust on them like when occurs on a dewy morning. When she begins to turn the wheel and apply brake, the pads polish the rust off and that process has a rough sound. When the vehicle is "warm" and not Maki g the sound that's because the brakes have been cleaned of the rust already. The person's symptoms may be due to simple schedule of driving.
Sent from my XT1585 using Tapatalk
OBX Exhaust Header & Downpipe / Magnaflow Highflow Spun Ceramic Cat / Vibrant Resonator / Flowmaster DBX Muffler/ 2.25" Piping upgrade / Weapon-R ShortRam Intake / 17" DC MESH Rims / Gunmetal Stubby Antenna / Polk Audio Compnents / 10" Rockford Fosgate Sub / Rock Fosgate 450watts for Interior Speakers / Rockford Fosgate 300watt for Sub / Rockford Fosgate 1 Farad Capacitor
Phames11 is offline
post #3 of 5 (permalink) Old 11-25-2016, 01:48 PM
I have the same issues the OP is having and I agree with you Phames, I think it is just changes in humidity.
Is there anyway to prevent this "flash rust"?
Why do we drive on parkways but park on driveways?
jmgarcia is offline
post #4 of 5 (permalink) Old 11-25-2016, 07:15 PM
Other than parking in a garage no.
post #5 of 5 (permalink) Old 12-08-2016, 08:15 PM
My car would make a super loud noise when going in reverse after a cold start however the noise would disappear when warmed up as described.
There have been few posts about it and most people brush it off as rust caused by humidity but when it happens every time whether garaged or not as it did with me, it is certainly not just a humidity issue causing rust although this would definitely play a factor.
In my case, turns out my rear caliper pins were not freely moving around so I cleaned them up and lubricated them. Cleaned my rotors and brakes with brake cleaner for good measure and now no more sounding like a train horn when i'm backing up.
I have seen some youtube videos with the same problem and in the comment section the owner said they fixed the problem by replacing their calipers as it was apparently seized.
Unsure if the caliper was actually seized or if it could have been solved by cleaning the caliper pins but might want to check those out.
If the noise happens once a while when there is a lot of humidity then I would say it is most certainly normal, but if you get the loud annoying embarrassing sound every time you reverse out in sunny California, I would most definitely check out caliper assembly and make sure everything is running as it should.
Despite what people say, IT IS NOT NORMAL FOR THE CAR TO MAKE THIS SOUND EVERYTIME.
ynggkim is offline
FS: Gen 1 hatchback LED 3rd brake light, Eonon and VG sharkfin ALTR EVO For Sale | M3F 7 05-23-2017 12:09 PM
Front outer brake pad rattling inside brake caliper m4rx Suspension / Brakes 11 10-05-2016 08:40 PM
2010 Mazda 3 (ABS)(TCS) and (BRAKE) lights on HELP!!! Nashi Mazda3 (Axela) 1 09-17-2016 09:22 PM
2005 Mazda 3 engine noise joef Powertrain 2004-2009 Mazda3 15 09-08-2016 08:53 AM
Brake pad not all on rotor eden_obscured Suspension / Brakes 2 08-25-2016 05:49 PM
