Koni FSD & Eibach kit on Stock Mazda3 Rubbing - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 5 (permalink) Old 08-27-2016, 02:41 PM Thread Starter
Send a message via Skype™ to Motonerd
Hi all,
I installed the above suspension last night and I've noticed that over large bumps or hard lock corners it "knocks", I believe its the Strut hitting the top of the tyre well, Has anyone else experienced this on stock standard 17x6.5 205/50/17 wheels and tyres? there's also a bit of steering wheel judder, would a wheel alignment be a smart idea?
I'd also like to add I've double checked all bolts/nuts etc
2007 Mazda3 GT Hatchback stock standard (other than struts and springs)
Motonerd is offline
post #2 of 5 (permalink) Old 08-30-2016, 10:36 PM
Definitely get an alignment after any suspension work. Did you replace shock/strut mounts? If those are worn it could cause the knocks. Did you check your swaybar endlinks as well as the other nuts and bolts?
koenb is offline
post #3 of 5 (permalink) Old 08-31-2016, 12:46 PM Thread Starter
I did replace my Front top hats and swaybar endlinks, checked all bolts, everything is tight. Im leaning towards the rear shock/strut mounts being worn. Any ideas where to pick up a nice pair locally to Vancouver?
EDIT: After several hours of searching I think I may have found my solution. Will check up tomorrow night and post a confirmation for all those who might be experiencing the same thing as me
Motonerd is offline
post #4 of 5 (permalink) Old 09-01-2016, 02:26 AM
Could also be your trailing arm bushings.
koenb is offline
post #5 of 5 (permalink) Old 09-09-2016, 09:05 AM Thread Starter
Ok!
Problem resolved.
Turns out the Koni Struts are thinner then the stock ones, I just clamped and pressed the mount together to stop them moving, there was about 5-6mm of play...
Anyone installing (Or has installed) Koni FSD's should check theirs out, could save you/them a bit of money.
Motonerd is offline
LinkBack to this Thread: http://www.mazda3forums.com/62-suspension-brakes/717921-koni-fsd-eibach-kit-stock-mazda3-rubbing.html
Koni FSD & Eibach kit on Stock Mazda3 Rubbing - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-28-2016 08:35 PM
