intermittent wheel bearing noise? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 10 (permalink) Old 08-25-2016, 12:01 AM Thread Starter
stupid8000's Avatar
About a month ago I got a very loud hum with a slight thump to it. It lasted all of 3 minutes and was gone till the other day. This time it lasted longer, but once I parked and came back, gone. It was also a bit of a different sound, smoother rumble like hum. Do I have a wheel bearing going out? Never had one be so random before.
Rebuild log coming soon
stupid8000 is offline
post #2 of 10 (permalink) Old 08-25-2016, 04:09 PM
You could have a damaged CV gaiter and it could be a bit of dirt getting into your CV joint.
Can you jack the car up and spin the wheels one at a time?
joef is offline
post #3 of 10 (permalink) Old 08-26-2016, 02:30 PM
Miata GT's Avatar
Which axle, front or rear?
Mark
2005 Mazda3i 5spd
1999 Rotrex Supercharged Miata @ 14psi
To a man with a hammer, everything looks like a nail.
Miata GT is offline
post #4 of 10 (permalink) Old 08-26-2016, 09:08 PM Thread Starter
stupid8000's Avatar
Its in the front. It did it a little only on the way to work today, not on the way home at all. If its making the sound, when braking the steering wheel will shake. This car only has 57k on it. Something with my brakes failing? It really sounds like a wheel bearing but I've never had one intermittent like this. Also the sound started getting VERY violent if I try to go 60mph or up.
post #5 of 10 (permalink) Old 08-27-2016, 05:09 PM
Miata GT's Avatar
A friend had something like this happen with a Mazda with no-so-tight lugnuts.
It's worth a shot.
Mark
2005 Mazda3i 5spd
Miata GT is offline
post #6 of 10 (permalink) Old 08-27-2016, 09:27 PM Thread Starter
stupid8000's Avatar
I have checked that hoping I just had a lose wheel somehow.
post #7 of 10 (permalink) Old 08-27-2016, 11:31 PM
I would check the brakes right away. Typically if the wheel shakes when braking then a front rotor is warped or severely rusted.
post #8 of 10 (permalink) Old 08-28-2016, 12:21 AM Thread Starter
stupid8000's Avatar
I just had the rotors turned in the spring for the 1st time to fix warp. But even if it was a warped rotor, it would always do it. I drive to work and back today and didn't have a single issue, 15mile drive one way, speeds up to 60ish.. So random.
post #9 of 10 (permalink) Old 08-28-2016, 07:12 AM
Could your hub nut be loose?
I'd jack it up and spin the wheel and give everything a good shake, you might find something loose.
joef is offline
post #10 of 10 (permalink) Old 09-04-2016, 02:17 PM Thread Starter
stupid8000's Avatar
Fixed, was a front caliper sticking of all things. After driving for a bit it would get hot enough and start chattering to make the sound.
