brake fade, boiling over r master cylinder issue
2K views 2 replies 2 participants last post by  3.2s
#1 ·
So after running this year a lot of autox
I've noticed an extreme amout of abs kickback, some where the abs system is getting so bad I lose brakes and blow threw the corner, I've noticed this after about 2-3 runs on heavy braking, I like to trail brake n I've blown threw 2 corners.bleed brakes multiple times. Well last weekend there was a quick shut down area after a nice stretch to go fast, I'd hit the brakes, it go about halfway to the floor, n then all off a sudden just like a quick grab.
Am I heating the pads n boiling the fluid, or is it my master cylinder not holding pressure under heavy braking. I'm running his pads centric blanks n valvoline dot 3 fluid
#3 ·
Well I switch to rpf600 techna fit ss lines but abs does do this n hpd are know for it so it's probably a double wammy curious what people with abs prefer ebc yellow hp+ or the new 5.0 pads
