New Coil Springs Squeaking!! - Help!! - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 2 (permalink) Old 07-24-2016, 05:30 AM Thread Starter
Hey all. I just installed my Tein S-Techs on my '15 hatchback yesterday, and driving around today I noticed a creaking/knocking noise coming mainly from the front struts. It gets worse whenever I go over a sharp speed bump, but with how low the springs go, any slight bump in the road I get the noise.
Things I've identified as possible issues:
  • Incorrect top hat orientation
  • Spring incorrectly seated (most probable)
To diagnose the problem I disconnected the sway bar end link and started jacking up the control arm with the strut attached. The spring itself is creaking whenever the strut moves up.
Also, the brown rubber that wraps around the spring on the bottom side is ripped. So it seems like the spring itself is not seated properly. But the end of the spring contacts the little notch at the bottom metal piece
tl;dr how should the spring sit on the bottom of the strut? should I take this to a mechanic and ask them to reinstall ?
peps_ecoli is offline
post #2 of 2 (permalink) Old 07-24-2016, 05:54 AM Thread Starter
Another possible culprit...
I might have reversed the springs, put the rear in the front and front in the rear. Would explain why my front sits higher. Is the skinny sprinf meant for the rear?? It doesn't seem like it since the control arm for the rear is so wide, the fatter shorter spring fit and Te skinny just moved around on it!
COIL SPRINGS WhiteHot3 Suspension / Brakes 7 01-08-2010 01:08 PM
Coil-Overs v.s. Springs jtluongo Suspension / Brakes 6 12-16-2008 04:41 PM
Coil overs or Springs silentlydyingx Modifications 2 11-07-2008 04:45 PM
squeaking noise in front end after springs... daveSP23 Suspension / Brakes 8 05-16-2006 11:04 PM
Stock coil springs godfatherga Suspension / Brakes 11 10-27-2005 11:55 AM
