Squeaking and Clunk - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 22 (permalink) Old 07-06-2016, 02:13 PM Thread Starter
Squeaking and Clunk
Hey all,
Had new rotors and pads put on all four corners over the winter.
The driver side front and passenger side rear have a rotational squeak. The faster the car goes the faster the squeak is and vice versa. Applying the brakes makes the squeak decrease substantially from the front and eliminates it from the rear. There is also mild pulsation in the brake pedal during heavy braking. What is causing this? Are the rotors already in need of resurfacing? Are the clips missing or something causing the squeak?
Secondly, the passenger side rear makes a clunk/metal slapping sound when traversing over bumps in the roadway. Kind of sounds like something metal is loose and slaps against another part when hitting the bumps.
ideas/solutions?
Thanks!
stslimited84 is offline
post #2 of 22 (permalink) Old 07-12-2016, 06:14 PM Thread Starter
Anybody?
post #3 of 22 (permalink) Old 07-12-2016, 06:21 PM
Gotta take it apart and see whats up. If there is a pulsation then at least one set of rotors need to be turned or replaced. Cheap pads are more likely to squeak and possibly warp the rotor. Also, check for any play in the wheels before you remove them.
post #4 of 22 (permalink) Old 07-12-2016, 07:23 PM
ultimica06's Avatar
Did you do a proper "Brake Bedding" after the install?
ultimica06 is offline
post #5 of 22 (permalink) Old 07-13-2016, 05:14 PM Thread Starter
Yes.
I'm confident the brake issue will be easily sorted out. I'm more concerned with the noise from the right rear. The car seems to be functioning normally aside from that noise.
post #6 of 22 (permalink) Old 07-26-2016, 10:10 AM Thread Starter
I'm going to be getting centric blanks and akebono pads to resolve the issue of the brakes and reduce dusting dramatically.
Also considering Koni oranges and a pro kit. Are the rubber spacers referenced in the following thread thread required or was that specific user having an issue related to his car? If required, what spacers are needed? Koni Str.T and H&R Lowering Springs Kit Install (no pics)
Any ideas about the clunk/rattle? its present going over any bumps regardless of speed. Sounds like a piece of metal slapping around. Car functions normally otherwise.
post #7 of 22 (permalink) Old 07-26-2016, 01:37 PM
Sounds like the rotors are warped--this tends to happen because the rotor can't dissipate the heat as quickly as it needs to, so thermal expansion makes them contract in a funny profile. I always get suspicious when cars need brake work so quickly after being serviced. Did they replace the rotors or resurface them? Cutting them thinner makes them even more prone to warpage.
As for the squeaking, my fix has always been to remove the pads and apply anti-seize (copper based) to all the contact points: where the piston contacts the backing, where the backing contacts the caliper bracket, etc. Sometimes you've just got a cheap brake pad and there's nothing you can do. And while you're right about ceramic pads making less dust, they are harder and thus make more noise. They also decrease braking performance--think hard tires vs soft tires.
Clunking noise I'm going to guess is sway bar end links. Pretty common, and an easy fix. Take a look at #4 in this diagram to see what I'm talking about: STABILIZER BAR & COMPONENTS. REAR SUSPENSION.. Fits: 2007 Mazda 5 | Cypress Coast Mazda
That's just an example because I don't know your exact make and model, but the setup's the same.
Hope this helps!
Musterman is offline
post #8 of 22 (permalink) Old 07-26-2016, 01:45 PM Thread Starter
Hope this helps!
Thank you for the reply.
My car is a 2007 mazda 3 s sedan. I think the mechanic just used cheap rotors and pads so I think putting fresh components on myself of a higher quality is the better route to go. I'll also flush the brake fluid. Any recommendations on the fluid? Was considering motul 5.1.
As far as ceramic pads go, how much noise are we talking about compared to non ceramic pads? The akebono get great reviews so that's why I was considering them. I'm open to recommendations.
Regarding the end links, what's the easiest way to diagnose that?
post #9 of 22 (permalink) Old 07-26-2016, 01:47 PM
11SELV6's Avatar
When did the squeak start? Assuming it has been there since they were installed, then I'd guess that the backing plate got bent during installation and that's rubbing on the rotor. If not, it's anybody's guess until it's taken apart and inspected. First thing I'd do is lift the culprit wheel(s) off the ground and spin them, looking right at it while it's making noise should narrow it down a bit. The rest of your braking concerns sound like things that occur from white-box parts being used...can't do much to fix that besides using better parts next time around. Resurfacing those rotors might help a bit temporarily, but of course, making them thinner only exacerbates the inherent problem.
For the rear end, I'd probably guess end-links too, as previously suggested. Also something that needs to be looked at to narrow down. Thankfully there aren't that many things that can be that loose while still having the car be functional. Just poke your head under there and start jiggling things if it isn't visually obvious.
2007 SEL V6 (no more 2011 SEL V6)
11SELV6 is offline
post #10 of 22 (permalink) Old 07-26-2016, 01:52 PM Thread Starter
The brakes were done around January or February. We got hit with a major snow storm I had to drive through and I think that may have caused the issue with the squeaking. It didn't squeak from the start but it's obnoxious now.
I'm planning on doing the brakes sometime over the next two weeks or so. Still debating if it's worth it or not to do the konis and eibach to freshen the suspension. Car is at 110k daily driven.
Appreciate all the feedback guys. Just a novice DIYer learning as I go.
I just checked the end links and they seem like they are tight as I was unable to move them by hand at all.
is there something else I should be doing? I'm wondering if a shock mount is broken.
LinkBack to this Thread: http://www.mazda3forums.com/62-suspension-brakes/714546-squeaking-clunk.html
Squeaking and Clunk - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 08:38 PM
Squeaking and Clunk - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-29-2016 08:38 PM
clunk,clunk, clunk while accelerating and turning right ribbit78 Suspension / Brakes 1 04-06-2014 11:03 PM
clunk clunk clunk on sway bar freddyboi Suspension / Brakes 35 02-11-2009 11:39 PM
clunk, clunk, clunk when steering at standstill invalidalias Suspension / Brakes 3 04-03-2008 12:39 PM
Clunk clunk clunk when very hard brake tailgate Suspension / Brakes 8 02-19-2006 02:39 AM
CLUNK CLUNK WITH NEW PADS - $165 for rear brake pad change??? prboy3 Suspension / Brakes 30 10-20-2005 10:10 PM
