Popping Noise Coming From Driver's Side Strut After Installing Koni STR.T - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By Miata GT
post #1 of 5 (permalink) Old 06-14-2016, 12:38 AM Thread Starter
Send a message via AIM to deathspared
Angry Popping Noise Coming From Driver's Side Strut After Installing Koni STR.T
Hello!
I need your help. I ordered new struts/shocks from TireRack recently for my 2005 Mazda3 2.3S Hatch. I had them delivered to TireRack's local installer. After picking the car up I noticed a popping noise coming from the driver's side wheel well when turning and going over bumps. For example, I can easily replicate it going in and out of my drive way while turning.
Unfortunately the installer is at a loss to what the problem is and I even went to another local garage where they too could not pin point it. So here I am asking you for any advice. So far I have replaced the strut mount with a Monroe mount. I have also replaced front sway bar end links with Moog.
Here is a video of the sound.
The noise is at 5 seconds, 14 seconds, 20 seconds, 27 seconds.
Thank you for any tips you might have to get rid of this annoyance.
deathspared is offline
post #2 of 5 (permalink) Old 06-14-2016, 07:10 AM
igor_harris's Avatar
Send a message via Skype™ to igor_harris
Try to clean and lubricate surface around top rubber hats, under and over mounting position as well. That sound like rubber noise, I have no other idea...
You can maybe check other rubber parts around suspension...
Also, that rubber hat (not sure how do you call it) make that noise more likely in cold weather condition...
Послато са 6039K уз помоћ Тапатока
igor_harris is offline
post #3 of 5 (permalink) Old 06-14-2016, 05:05 PM
Miata GT's Avatar
Could be that they accidentally popped the roller bearing piece at the top of the strut and either didn't find all the ball bearing or didn't lube them back up.
r2rrita likes this.
Mark
2005 Mazda3i 5spd
1999 Rotrex Supercharged Miata @ 14psi
To a man with a hammer, everything looks like a nail.
Miata GT is offline
post #4 of 5 (permalink) Old 06-14-2016, 05:43 PM Thread Starter
They didn't replace the stock strut mount when installing the strut to begin with. I actually had another shop install the Monroe mount in hopes of getting rid of the noise but it didn't help. That is also why I replaced the end links to no avail.
post #5 of 5 (permalink) Old 06-15-2016, 11:22 AM
Miata GT's Avatar
The part I'm talking about is not part of the mount, it sits on the front struts to allow the assembly to swivel during turning (I believe). The first time I replaced the struts on my 3 I discovered this surprise.
Mark
2005 Mazda3i 5spd
Miata GT is offline
LinkBack to this Thread: http://www.mazda3forums.com/62-suspension-brakes/712721-popping-noise-coming-drivers-side-strut-after-installing-koni-str-t.html
Suspension / Brakes [Archive] - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-04-2017 07:48 PM
Weird Popping noise driver side front wheel eljean Suspension / Brakes 6 07-08-2014 05:25 PM
!help! bad thudding, clunking, and popping noise from front driver side. azntaiji Suspension / Brakes 12 09-23-2010 02:46 PM
WTB/trade Driver Side Strut. Or set of Koni Yellows. DranCoin For Sale | M3F 1 03-22-2010 05:44 PM
Help...weird noise coming from front driver side. FC MazdaSpeed3 Stock Issues 10 07-16-2008 08:24 PM
Wind noise coming from driver side. jichoe MazdaSpeed3 Stock Issues 0 06-11-2008 02:36 AM
