Need advice on new suspension kit (+ mounts?) for my '09. - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By chaos
post #1 of 10 (permalink) Old 06-08-2016, 12:42 PM Thread Starter
chaos's Avatar
So I'm at 107K and at least my rear springs are pretty much shot. Probably all four, but the rear is all I had looked at after I started getting a clunking noise and oil leakage from the rear right. The guy at the shop told me I needed new springs and new mounts.
So I was planning to just get the Koni STR.T kit here. However, I'm a bit confused being a noob to this stuff. I don't see that this kit includes mounts. So do I need to purchase the mounts separately? And if so, do I need four mounts? And can anybody point me in the direction of what mounts to buy? I've had trouble finding the answers on my own.
Or, alternatively, or there any different kits I should be looking at? I don't need high performance, I would just like something that's a modest upgrade over OE performance.
Thank you to anybody who can help.
'09 2.0 ATX | Lip Spoiler | JDM Visors | Enkei RPF1 | PureContact | Hawk HPS | Roca MM | Simota SRI
chaos is offline
post #2 of 10 (permalink) Old 06-08-2016, 12:55 PM
ultimica06's Avatar
KONI STR Struts/Shocks are an OEM Replacement...not recommended w/ Lowering Springs from what I have read about other people having issues.
The factory Strut Mounts are crappy made of plastic....I know they make metal Strut Mounts but are Pricey!!!
KONI Yellows are the best to go with Lowering Springs.
If you are on a Budget I suggest Eibach Sportline Lowering Springs w/ KYB Gas-a-Just struts/shocks....this rides very OEM like but provide a slightly stiffer and a lot better handling...I had this set-up for 3yrs.
I upgraded to ISC Coilovers...Best decision I made Suspension wise....great for Daily Driving and then going for a Mtn. Cruise where there are curvy roads etc...Plus I wanted to slightly lower then what Lowering Springs had to offer.
ultimica06 is offline
post #3 of 10 (permalink) Old 06-08-2016, 01:23 PM Thread Starter
chaos's Avatar
What's the price comparison (roughly) between your budget option of Eibach / KYB and what you upgraded to (ISC Coilovers)?
I'm not looking to lower my 3 at all, for what it's worth. I just basically want to replace my suspension, but with something slightly better than OEM. So what you described with the Eibach / KYB setup may be perfect. Where would I purchase that?
Edit: Or minimal lowering.
chaos is offline
post #4 of 10 (permalink) Old 06-10-2016, 12:12 PM Thread Starter
chaos's Avatar
Okay. After doing a ton more research on my own, I settled on Koni SRT.T shocks/struts, Moog springs (standard/non-lowering), and KYB mounts/boots. I'm hoping those all work together as a suitable OEM replacement/slight upgrade on my budget.
Adam3324 likes this.
chaos is offline
post #5 of 10 (permalink) Old 06-20-2016, 12:37 AM
leftthebtch's Avatar
I went with Racing Beat Springs...they are a perfect fit for my Mazda 3 sedan ...they haven't bottomed out yet and I've been driving hard on them for a month. I went with koni yellows...struts in front and shocks in the rear ...can't complain about the new setup ....but I'm sure you'll get an earful from some cocky people who think they know it all ...good luck
Sent from my SAMSUNG-SM-G935A using Tapatalk
leftthebtch is offline
post #6 of 10 (permalink) Old 06-20-2016, 12:41 AM
post #7 of 10 (permalink) Old 06-20-2016, 12:43 AM
yeah I know what your going to say so save it Obie one ..it's my car and yes I did it my way
post #8 of 10 (permalink) Old 06-20-2016, 02:55 PM
KYB better than Koni?
And pillowball mounts are not for a daily driver unless you want to rattle the teeth out of your head.
Someone's been smoking the good stuff...
myork is offline
post #9 of 10 (permalink) Old 06-20-2016, 11:05 PM
DarthR8er*'s Avatar
How much of a drop did the RB lowering springs give your 3? I have the Mazdaspeed accessory lowering springs on my 2006 hatchie and I love the stance but it tends to bottom-out in the front more than I would like. I have Koni STR's in all four corners.
DarthR8er* is offline
post #10 of 10 (permalink) Old 06-29-2016, 05:05 AM
Are you done installing them? How's ride quality?
dyllanrt is offline
need some advice on suspension Acradian9 Suspension / Brakes 4 03-10-2010 03:52 PM
how much to install suspension? (also list of my suspension kit) XB Suspension / Brakes 14 07-14-2009 06:56 PM
suspension advice!! Inspecta 22 Suspension / Brakes 4 03-16-2008 12:08 AM
upper mounts on suspension. tnereffidxmitch MazdaSpeed3 Modifications 2 12-17-2007 05:48 PM
