Racelands Ultimos on a Mazda 3 - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By XCNuse
post #1 of 3 (permalink) Old 06-06-2016, 09:10 AM Thread Starter
777scribner's Avatar
So recently I purchased off of craigslist brand new still in the box Raceland Ultimos. Got them for a really good deal $250 just had to drive to Albany NY to get them(1hour35min drive) not to bad. I know people say thay arent great but ill shortly find out. Just wondering if people have a write up installing them or videos/pictures of doing it. Thanks and let the hate begin.
777scribner is offline
post #2 of 3 (permalink) Old 06-06-2016, 09:42 AM
Same as any other coilover, just that you have to use the OE top hats (GET NEW ONES!!!!!!!!).
Coilovers are easy, easier than springs.
I think the only tools you need is a 12mm, 14mm, and 17mm, and whatever size the allen key is for the endlinks. Depending on your front knuckles, you may need a nickel, or just a spreader bar.
Basically all you do is jack up car, disconnect all endlinks,
make SURE if you have ABS, to remove the wire from the knuckle first. up front, remove the bolt that goes in the pinch on the backside, use a block of wood and hammer or widowmaker jack to separate the old shock and spring from knuckle, remove 3 tophat bolts, and replace.
For the rear, just remove the bolt that holds the shock in at the bottom, and kick the knuckle and the spring will fall out (make sure sway bar is rotated out of the way, so the control arm can drop down). Stock springs suck.
From there, remove two nuts at top of shock, insert new springs and shocks, bolt it all back up... pretty much it.
It seriously is as easy as it sounds.
Used to be able to swap spring setups to coilovers in less than 40 minutes.
777scribner likes this.
post #3 of 3 (permalink) Old 08-26-2016, 02:24 PM Thread Starter
Life got in the way for a while but tomorrow is the day everything goes in. Thanks for responding and giving me the tips. I will have pictures put up hopefully by the end of this weekend.
Suspension swap - OEM for Raceland Ultimos - Success subjectnate Powertrain 2004-2009 Mazda3 5 03-12-2016 06:27 PM
Hello from DC (RACELANDS??) SEMPERGUMBI Introductions 4 02-20-2015 07:51 AM
Showoff your racelands newborn3 Suspension / Brakes 2 11-15-2012 10:33 PM
FS: Various TWM Short Throw Shifters (Mazda Protege, Mazda 3 and Mazda MP3) laraw For Sale | M3F 31 01-25-2012 05:17 PM
