2010 Mazda 3 Clunking (found issue/brakes) - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By SgtGuitar
post #1 of 4 (permalink) Old 05-15-2016, 02:47 PM Thread Starter
Hey guys.
A couple months ago i replaced all 4 sets of brakes on my 3. Shortly after I noticed a clunking when going over bumps and the like at slow speeds, however it didn't seem to happen when going highway speed.
After looking at the forums and different websites I diagnosed it with bad swaybar endlinks, which were probably overdue anyway since the car has 120k miles. Well yesterday I replaced them (pain in the butt! nuts and the allan hole stripped - dang cheap metal). However that didn't solve the issue at all and I was dreading that it may be a Strut mount, or the strut itself though both looked to be somewhat in tact - though worn.
Well I went to a buddys while taking off the endlinks since I ended up having to cut them off due to the cheap metal, and he stood outside the car and listened as I drove it slowly and informed me that the noise sounded like it was coming from the brake area. So we pulled the back tire off and pulled the caliper and were messing with the brakes for house. I noticed that upon tightening the bolts that attach the caliper to the mount, the caliper still had some play even after tightening the piston back up (pressing the brake pedal).
One thing I noticed that wasn't in any of the brake tutorial/walkthroughs were the little holes (where you put the tool to compress the piston), and the knobs on the pads themselves. I didn't try to match these up before, though I did this time but they were actually a little bit off so wouldn't fit (not sure if this is actually necessary).
So here I am, I am stumped! I don't know why my car is making this noise but I did notice that after playing with the caliper yesterday its about 90% better but there is still noise so I want to fix it to 100%.
Also - on passenger side rear I notice that my pad isn't contacting 100% of the rotor. So there is a wide band of rust where there shouldn't be, however this one isn't making noise.
Could it be the brake pads? Or is it the caliper? I sure hope its not the caliper as that is just as costly as new struts!
OH - I bought the duralast gold ceramic pads from autozone. Im assuming they gave me the correct brake pads. Heck IDK but i'm at my wits end and I need the mazda experts here to maybe help me solve my issue.
Thanks in advance! if i missed anything or was too vague please ask and I will help clarify!
SgtGuitar is offline
post #2 of 4 (permalink) Old 05-15-2016, 08:18 PM Thread Starter
Well crap! Ok so I have been trying to research a little while I awaited an answer from someone here (which hasn't happened yet despite the views) and I think maybe I have found something?
I kept noticing that there were pads on some types of brake pads that had a little spring on one of them. Well i went on AZ website, and looked up rear pads for my vehicle, and what do you know? Apparently my rear pads are suppose to have a spring on them. Could this be my problem? I wonder why I was given the pads without the spring.... I bought the duralast gold ceramic pads (I believe). its been a couple months but I am going by the store tomorrow to consult them about this, as now I have a rotor that seems to be gouged.
post #3 of 4 (permalink) Old 05-15-2016, 11:10 PM
GerryBuc's Avatar
Get hardware kits for your year car, install them. Make sure all surfaces are clean and rust free, then grease them with high temp grease, even the backs of the pads. Reassemble. Profit.
GerryBuc is offline
post #4 of 4 (permalink) Old 05-26-2016, 10:47 AM Thread Starter
Ok great news!
So I was looking at the pads, and apparently I had 2 of the same on each side (stupid). I didn't even realize it though. I had someone showing me how to do the brake change as it was my first time and they had placed a set of pads on each side. I guess he didn't realize it either, sadly.
However, I pulled off the pads from both sides, I place one of each (a new fresh pair) with the spring on the inner (near piston). Replaced caliper and proceeded to do the same thing with the other side.
Put it all together and now its working like a champ. The rotor on the passenger side is now making full contact with the pad, and the noise from driver side is fixed now too.
Sure I spent extra money on new sway bar links thinking it was those, but heck at 120k miles they probably needed achange
Jchu14 likes this.
Anyone found the hidden nav menus, etc in the 2010 Mazda 3? dougs2010mazda3 2010-2013 Electronics Discussion 9 11-18-2014 12:43 PM
clunking sound whenever i hit the brakes r4ymond88 Suspension / Brakes 3 10-11-2010 11:01 PM
Brakes problem on my new Mazda 3 2010!!!! juanram007 Stock Issues 1 11-17-2009 04:18 AM
MOVED: Found the rear clunking in MY POS 3 (sorta) HairlessBeachApe Mazda3 (Axela) 0 11-03-2005 09:33 PM
Found the rear clunking in MY POS 3 (sorta) wdvelomd Stock Issues 8 11-03-2005 09:13 PM
