need help diagnosing problem: Wheel play and front passenger wheel seems loose - Mazda3 Forums : The #1 Mazda 3 Forum
  • 1 Post By lout
post #1 of 8 (permalink) Old 05-13-2016, 03:44 PM Thread Starter
so i need help diagnosing what this problem could be. There is wheel play on the front passenger side when i move the tire around compared to the other side. Also it seems more prevalant when its wet and the wheel/axle seems to give way and i loose some traction on turns only. Any one know what i should be looking for under the car? Please help. I've previously replaced the struts, passenger motor mount, tires.
could it possibly be the wheel bearings?
wakko is offline
post #2 of 8 (permalink) Old 05-13-2016, 04:19 PM
GerryBuc's Avatar
Could be. Could be tie rod ends, too. And perhaps control arm bushings, but to a lesser extent.
GerryBuc is offline
post #3 of 8 (permalink) Old 05-13-2016, 07:46 PM
as steering is kind of important i would have a professional shop give you a quote
are you finding movement front to back ,
top and bottom rocks in
or as in steering left and right rocks in
GerryBuc likes this.
lout is offline
post #4 of 8 (permalink) Old 05-13-2016, 09:39 PM
GerryBuc's Avatar
And this.
GerryBuc is offline
post #5 of 8 (permalink) Old 05-14-2016, 11:55 AM
I noticed a weird turning issue was my ball join on my lower control arm, not much play in the wheel, normally wheel bearings make noises axles makes vigurious clicks
3.2s is offline
post #6 of 8 (permalink) Old 05-15-2016, 01:00 PM Thread Starter
It seems to only occur during wet rainy times. I jacked up the car and everything looked ok except the control arm. Grease all over the driver side control arm. Could this describe the problem?
With the wheel on I couldn't get any wheel play in steering or the wheel. Up, down, side to side, anything. Maybe the rain makes the control arm slip a little and describes my issue about the wheel giving a bit?
wakko is offline
post #7 of 8 (permalink) Old 05-15-2016, 01:28 PM
The grease on the control arm is most likely due to a torn CV boot.
If something is loose then you most likely should be able to feel it in the wheel when the car is jacked up. If not then you have to start prying on things.
post #8 of 8 (permalink) Old 05-15-2016, 01:44 PM
GerryBuc's Avatar
I would seriously have that entire front end looked over really well if you're not fully familiar with everything going on up there. Just sayin.
GerryBuc is offline
Diagnosing wheel sound tchiarella Suspension / Brakes 8 04-23-2015 05:47 PM
Replaced passenger front wheel bearing... X Squared Suspension / Brakes 3 10-06-2012 05:24 PM
Hollow "clunking" noise from front passenger wheel pjarcher Suspension / Brakes 8 12-21-2008 12:47 PM
clicking noise behind passenger front wheel jstassen MazdaSpeed3 Stock Issues 0 05-18-2008 01:33 PM
