Increase rear braking power ?? - Mazda3 Forums : The #1 Mazda 3 Forum
 4Likes
  • 2 Post By shipo
  • 2 Post By XCNuse
post #1 of 7 (permalink) Old 04-26-2016, 04:34 PM Thread Starter
rdtk's Avatar
My understanding is that the front brake do most of the work. I also am hearing from some people I know that the newer cars are starting to put more even braking power across rear/front and in some cases more in the rear.
I have Hawk fronts with cross drilled and ok pads with ok rotors in the rear. Looking to add steel brake lines, also orange koni's all around and have TEIN springs, waiting for temp to go higher and I will be lowering.
That being said, after I lower my car and have a higher spring rate, is there a way to mod my brakes so that there is even power for my front and rear brakes??
Bad idea??
Good Idea?
Is it possible?
Stopped count mods at 30
rdtk is offline
post #2 of 7 (permalink) Old 04-26-2016, 05:31 PM
Super Moderator
shipo's Avatar
Bad idea; you drive a FWD car with a front weight bias; if you up the braking power of your rears, even with ABS doing it's darndest to prevent wheel lockup, you run the risk of having the back end come around on you in an emergency braking situation or when you least want it while braking into a hard turn/curve.
slavuta and GerryBuc like this.
1999 Chrysler T&C Limited
2001 Honda Accord V6 EX
shipo is online now
post #3 of 7 (permalink) Old 04-26-2016, 05:45 PM
Administrator
If you brake lighter, you have more rear bias.
If you brake harder, you have more front bias.
Hence why easier drivers in 3s and newer cars burn out their rear pads before fronts.
post #4 of 7 (permalink) Old 04-26-2016, 05:57 PM Thread Starter
rdtk's Avatar
Acknowledged, Thanks!!
rdtk is offline
post #5 of 7 (permalink) Old 04-26-2016, 06:20 PM
Administrator
The reason for the more bias in the rear during light braking conditions is to keep the vehicle from diving. It's to keep it flat while braking, thus, more comfortable for any passengers.
Obviously however, too much rear bias under heaving braking is very dangerous, thus the load instead prefers to the fronts, where comfort is obviously no longer necessary, as the vehicle... needs to stop.
post #6 of 7 (permalink) Old 04-26-2016, 09:21 PM
GerryBuc's Avatar
That figures. I'm generally pretty light on my brakes. Looks like I'll need to replace them in 20k...
GerryBuc is offline
post #7 of 7 (permalink) Old 04-28-2016, 05:52 PM
slavuta's Avatar
If you want to increase braking power, you should go proportionally on both, front and rear. You need larger disks/pads and possibly, double-piston calipers (at least in front). But then again, it will cost and replacements most likely are not readily available. Therefore, try to make best out of what can fit on your car without modifying dimensions.
98 Protege
10 Mazda3
11 Mazda3
Next - not Mazda
(may be)
slavuta is offline
How to get a noticeable power increase? Darrickdman Powertrain 2004-2009 Mazda3 21 09-11-2012 08:19 PM
How much of a power increase with CP-E standback??? onetechyguy MazdaSpeed3 Modifications 17 10-12-2007 01:49 AM
21% power increase? civicex2g Modifications 3 03-24-2004 11:11 PM
