Front passenger camber off - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 8 (permalink) Old 04-18-2016, 11:26 PM Thread Starter
Guys,
I lowered my car (09 mz3 2.3L) on koni yellow and H&R springs. Afterwards i did an alignment. The shop was able to get every value in range except for the camber on front passenger tire. The current value is -1.9 deg and the range shows b/w 0.3 deg to 1.7 deg. The guy tried everything to get the camber in range, but couldn't. Please see the attached.
My question is how come every other value is in range except for the camber on the front passenger side. Will having a camber kit help bring the value to the preferred range?
Thanks,
Aaron
babumazda3 is offline
post #2 of 8 (permalink) Old 04-20-2016, 08:47 AM
remnant01's Avatar
A camber kit would probably do it but you could also shift the subframe over two tenths to balance both cambers out to -1.7 deg. The actual shift is easy. Hardest part is setting it all up level. Two tenths wouldn't require much of a shift either. Check out my post on the last page of the Wheel Alignment Super Thread in this forum category.
My other car is a Honda Civic...
remnant01 is offline
post #3 of 8 (permalink) Old 04-20-2016, 10:40 AM
Administrator
positive toe... huh.
No need really for a camber kit.
Are you sure he "tried everything"? Because trying everything involves unbolting the top of the strut and moving it around. I bet he didn't touch it, because there is enough adjustment.
To be honest, that's hardly a big deal.
Unless you plan on putting several thousand miles per week on your car, you'll be fine if you continue to rotate your wheels.
post #4 of 8 (permalink) Old 04-20-2016, 08:24 PM
Looking at the before and after readout all that mechanic did was adjust the front toe and nothing else. The left rear toe should have been tweaked as well as the front camber and caster while they were at it.
post #5 of 8 (permalink) Old 04-21-2016, 07:14 AM
remnant01's Avatar
It really is hard to find an alignment mechanic who will do the job right. Last time I went to one I told him that I have adjustable SPC camber links and toe arms in the rear and he ignored them, preferring instead to just twist the factory eccentric bolts. He put the rear toe in but completely messed up my camber settings. I had to go back and reset them myself. Grrr.
post #6 of 8 (permalink) Old 04-21-2016, 08:00 AM
Administrator
If you aren't paying over $100 for an alignment each time... chances are you aren't going to get a good alignment lol
That's my general rule of thumb whenever someone has alignment questions, and of course they always come back and have some "lifetime" alignment deal.
Not all places though will touch even the SPC camber arms. They're still difficult to do and get to when the car is on the ground.
Other ones... you just can't do period without removing everything.
post #7 of 8 (permalink) Old 04-21-2016, 08:33 AM
remnant01's Avatar
Yeah I know but my cambers where a nice -1.3 deg on both sides. All he had to adjust was the toe links. Instead he used the factory eccentrics. Yeesh.
Paid $85 BTW.
post #8 of 8 (permalink) Old 04-21-2016, 09:18 AM
Administrator
Yeah, this is why I've just started doing my alignments myself lol
WTB: 04-09 Mazda 3 Rear camber arms, passenger side floor mat incdalton Want to Buy | M3F 5 03-30-2012 12:30 AM
WTB: Driver side front fender, passenger side front door donson Want to Buy | M3F 0 08-30-2010 02:52 AM
WTB OEM or aftermarket MS3 front bumper Hood, passenger front fender other misc Tooch For Sale | M3F 2 08-19-2009 11:18 AM
WTB: 2004 - 2006 Mazda3 GT red front bumper cover and front passenger fender bad_azz_bmr For Sale | M3F 0 10-16-2007 10:42 PM
front camber Pegalis Autocross, Track, and Dyno Results 8 09-24-2006 11:20 PM
