Replace trailing arm bush difficulty? - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 58 (permalink) Old 02-20-2014, 07:08 PM
sheldor's Avatar
I don't actually recall the process or how difficult it was or what it looks like under there :P but I don't remember it being hard if that's any help to you lol.
[Yonaka coilovers (bilstein shocks in the rear)] [30% tint] [JBR passenger motor mount] [6500K HID's] [Independent fog light mod] [Hankook winter iPike tires (winter mode)] [parking light delete] [intake resonator delete] [EBC green stuffs break pads] [powerslot front rotors] [second horn] [2008 Ford Fusion 2.3L]
sheldor is offline
post #12 of 58 (permalink) Old 02-21-2014, 10:44 AM
Trailing Arm And Bushing Removel and Replacement
This is the guide that I used. Notice it isn't complete after removal. That's not a big deal, because it just goes back in the reverse order. I did mine a couple months ago. I don't think it could (or possibly even should) be attempted while on the car. After I did those bushings. I ended up getting a set of SPC camber arms, and then MOOG everything for the front and rear. I am very happy with MOOG after comparing them side to side with the FoMoCo stuff on there. You seem to know your stuff, so replacing these bushings should be fairly easy for you. The only "trouble" I ran into, was getting the rust to let loose. Grab a can of PB Blaster and hit whatever you want to and let sit to soak for a little bit. A press would be helpful for pressing in the bushings, but I bet a couple clamps could get the job done in pinch. I would also recommend keeping the bushings in the freezer until ready to install.
2005 Titanium Grey Mazda 3s with exhaust, VG Sharkfin Antenna, KandN Typhoon intake, Code Alarm CA6552 Remote Start/2 way alarm, Remote Trunk Release, In Dash DVD, Upgraded speakers, Rear View Camera, 17x8 MB Weapons, DDM 5000k HID's, Nebraska Legal Tint, Hitch and Trailer Wiring (for the bike rack)
bakracer21 is offline
post #13 of 58 (permalink) Old 07-18-2015, 04:46 PM
Do I need a press to replace the lower control arm bushings
3.2s is offline
post #14 of 58 (permalink) Old 07-18-2015, 04:47 PM
Also how was replacing your trailing arm bushings what press did u use
3.2s is offline
post #15 of 58 (permalink) Old 07-31-2015, 05:55 PM
yes a special press is needed for the bushings. Labor by the book is about 2 hours each side
I just replaced my rear passenger trailing arm bushing, no more clunk!
SatinCruise8 is offline
post #16 of 58 (permalink) Old 09-04-2015, 03:37 PM
Originally Posted by XCNuse View Post
So there is absolutely no way to do that with it still mostly on the vehicle is there? lol
I'm not really in the mood to spend 6 hours taking apart my entire rear end to replace one bush.
^^^^^^^^^^^This...
I had the exact same question. I've seen a few you tube videos where guys manage to muscle the trailing arm down just enough to get the bushing down below the frame to a workable location.
I'm not sure if buddy was working on a Mazda 3 or not though...
Regardless, has anyone been able to pull this off?
Joe B. is offline
post #17 of 58 (permalink) Old 09-04-2015, 04:19 PM Thread Starter
Administrator
I can't decide if I want to try; that's right, I still haven't done it LOL
But the car is in literal bits right now so I might as well?
I think I should give it a shot, see how it goes.
That is, if I can do it without removing to much. If I can undo the shock, camber arm, and the bushing mounts and access it, then other than finding a way to press it out, I think I could handle it.
post #18 of 58 (permalink) Old 09-04-2015, 05:33 PM
just send it in to your mazda dealer BUT make sure they have a press. I have actually spoken with 2 mazda dealers who stupidly did not have it....(being that it's such a common issue with our mazdas)
have them replace the bushing. It's cheaper and no headache what so ever, rating than trying to do it yourself
post #19 of 58 (permalink) Old 09-04-2015, 06:03 PM
I literally just finished reading the procedure and spraying down bolts I will have to move with penetrating oil. It is definitely an intimidating job since it involves tearing the whole rear end apart but really, it isn't THAT bad. As for pushing out the old bushing and putting in a new one, there are some genius home made tools out there doing it pretty easily. My favorite one that I saw online, either in this forum or another similar one, involved drilling a hole through two pipe end caps, using a piece of threaded rod, a socket or two and some nuts for a make shift bushing press/removal tool. Seemed to work pretty well and could be easily adapted for different bushing sixes... I'll let you know how I make out in a couple weeks when I do the job! I might even make a thread about it depending on how faithfully I can take pictures throughout the process.
I was quoted $600 labor at my local Canadian Tire. I don't even want to know what the stealership wants....
I am also going to be doing rear shocks and the lateral links while I am in there... So, what the hell right?
Joe B. is offline
post #20 of 58 (permalink) Old 09-04-2015, 07:17 PM Thread Starter
Administrator
I typically have ended up using sockets (very large ones for old flywheels lol), and C clamps, if I can't use a bench vice.
Having the proper tool of course would make the job twice as easy at least!
If you're taking apart half of those things anyways, IMO you certainly might as well; maybe even do camber arms if you haven't.
If you do, and are successful, mind taking pictures??
Even maybe writing up a how-to?
Bent Trailing arm ZoomZoom999 Suspension / Brakes 3 12-14-2013 06:44 PM
Trailing arm bushing and other help Please! Qmann Suspension / Brakes 0 02-10-2013 07:57 PM
