Front Suspension noise (tac-tac) makes me go crazy! - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 10 (permalink) Old 08-18-2009, 03:12 PM Thread Starter
Hello, i have searched through this forum but can't come to a solution so i would imagine this is a very unusual problem with my 2005 mazda3. In my front passenger side suspension, i often get a 'tac-tac' noise when going over humps, something which my mechanics can't figure out. I have spent an awful lot of money fitting in new shock absorbers, changing the rack ends as well as the stabilizer links but the noise is still there! Has anyone come across this problem? Please help;(
flaggmann is offline
post #2 of 10 (permalink) Old 08-18-2009, 10:38 PM
Re: Front Suspension noise (tac-tac) makes me go crazy!
look at the passenger mount (next to coolant tank) to see if rubber is broken. Look for resulting oil spill on the frame, from the broken mount.
2006 copper red sedan
bulletcatcher829 is offline
post #3 of 10 (permalink) Old 08-18-2009, 11:19 PM
i had a front sway bar endlink go bad on the front due to the little dust boot getting cut and the lubricant leaking out, which made a clunking noise when going over any bumps. to diagnose on my car the broken endlink had some play in it, so you could move it ever so slightly back and forth (the good endlink was rock solid in comparison).
Oricle is offline
post #4 of 10 (permalink) Old 11-15-2009, 08:02 AM
[quote author=flaggmann link=topic=153711.msg3284919#msg3284919 date=1250619172]
Have you found any solution to this?
Heard that Upper Rubber Mount of the Strut Assembly is a cause for 2004/2005 Mazda3.
rohanda is offline
post #5 of 10 (permalink) Old 11-15-2009, 03:16 PM
try this
http://www.finishlineperformance.com...02-06-1589.pdf
5l1mm is offline
post #6 of 10 (permalink) Old 11-16-2009, 10:49 AM
[quote author=5L1mm link=topic=153711.msg3418163#msg3418163 date=1258312573]
try this
Hope that Flaggmann referring to a tag-tag noise which is different from squeaking noise come from Lower Arm end .
Please refer following link(TSB for MZ3 2004) which could describe Strut Mount Rubber problem.
http://www.protegefaq.net/tsb/02-002-05.html
rohanda is offline
post #7 of 10 (permalink) Old 11-17-2009, 03:33 PM
[quote author=rohanda link=topic=153711.msg3419002#msg3419002 date=1258382997]
yeah, that looks like it makes more sense.
5l1mm is offline
post #8 of 10 (permalink) Old 09-17-2010, 05:19 PM
Check out the brakes....i had the same problem w/ mine and the mechanics couldn't figure out what it was until one of them disassembled the front and rear brakes and noticed that they were not held in place properly.....he ended up glueing the pad in......i have ceramic pads w/ a lifetime warrantee so they won't need to be replaced again
J_ROC is offline
post #9 of 10 (permalink) Old 09-24-2010, 09:46 PM
Send a message via AIM to zoomm3zoom
^^^ Lifetime warrantee doesn't mean that they are going to last a lifetime. hope you know that. they are warranteed for a lifetime not to fail or break or something like that but not to wear out like all breaks/parts do. so you will be replacing them at somepoint down the road.
'05 3i 2.0 Velo Red~18" ASA AR1's, Magnaflow Exhaust, EBC RedStuff, TWM Short shift, Mazdaspeed Accessory Sways, Racing Beat Front Endlinks, Kenstyle Lip Kit & Grill, Euro Clear Red Tails W/ Amber Signal, SU Passenger Side Mount, AWR Rear Mount, Advanced timing, TB Ground, Removed Intake Resonator, Removed Door Moldings, 55watt 6000k HID headlights, Silverstar Turns, LED Tail Light Bulbs, Sok07 Dead Pedal, Stubby, 20% Tint & Banner, K&N, 2 12" Infinity Kappa Perfect Subs.
zoomm3zoom is offline
post #10 of 10 (permalink) Old 11-03-2010, 12:32 AM
Banned
[size=8pt]Quote from: zoomm3zoom on September 24, 2010, 08:46:55 PM[/size]
You got that right. In a long run, you need to replace a part or two. Here's a list for you to check: shock absorber, struts, ball joints, lower control arm, bushings, sway bar links and more.
ndrewoods is offline
