rear tires cupping on the inside - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum
post #11 of 30 (permalink) Old 06-26-2009, 04:06 AM
Re: rear tires cupping on the inside
[quote author=wolph69 link=topic=148367.msg3187602#msg3187602 date=1245459553]
yeah I got a printout everytime, and I only went to the same place twice because I didn't want them to get annoyed and screw something up. I do carry alot in my car but most of the time it's pretty light. I'd say at the most I have 40 pounds of stuff in the back, but most of time time it's much less.
40lbs is not a lot of weight and prob isn't the cause for this problem
HKS CB - K&N CAI - Eibach Pro-Kit - Hood Struts - Grounded TB - 35% Tint - Red Calipers W/Mazda Decals - Shark Fin - Side Molding Delete - 4100K Fogs
bnwsting97 is offline
post #12 of 30 (permalink) Old 06-28-2009, 04:06 PM
wildfrisco's Avatar
[quote author=wolph69 link=topic=148367.msg3187556#msg3187556 date=1245457406]
This is my second brand new set of tires. First cooper tires, not Bridgestone tires. I replaced the coopers because they got so bad my steering wheel shook after I rotated the tires from the back to the front. I rotate every 3k miles to try and avoid this so all 4 end up getting bad cupping. Now the bridgestone stires are doing the same thing and ony on the rear... both sides passenger AND driver. I have had an alignment every 3k miles ( I know it's overkill but I wanted to make sure) and had the toe set to 0 on all 4 corners. I don't know where to go from here. Any suggestions on why my tires are getting cupped after only 10k miles? I've heard bad shocks in the rear can cause this but i've checked them and they are fine. Any ideas?? I love this car, but if I can't find a cause to the tire cupping I'm going to have to trade it. I drive for work so 10k miles is about 3 months. Also, car is stock. It's funny because you can see the wear on the rear tires they doin't seem to be even touching the road on the outside of the tire. Can too much Camber cause this?? It is well within mazda spec at about a degree.
Myself and others have had the exact same problem. I've had 3 sets of tires in the back. So far it's happened to the first two after thousands of miles of driving, say 10K. When it feathers, it's also accompanied by a noisy hum. This is partly why I don't rotate the tires since I don't want the noise at all 4 corners.
On my 2nd Yokohama S.drive set, you could actually see that on the inner tread, they alternated in darkness. Black, dark gray, black, etc as if every other tread block wasn't touching the ground and just getting dusty.
Many drivers here say rotation is key but as we've experienced, it doesn't help, just eventually creates more interior noise. Nobody really seems to know or have had it resolved. I suspect toe, but you stated yours is zero'd out. Others have stated negative camber, but in my experiences with other cars it just causes the inner tread to wear out much faster.
Never had the car aligned since I bought it in '07, since the tech stated each time that the car is within spec. Factory specs are a little generous though so I may take it to a shop with higher standards. I have 60K miles and the shocks are still good via the bounce test.
Hypertech MESPP, Aasco lightweight flywheel, Medieval lightweight pulleys, 60mm throttle body, track pipe, Cosworth air filter, OEM BBK (Ms3 front & Mz5 rear brakes), Endless pads/DBA rotors, Koni FSD, OEM '04-06 16" Mz3 alloy wheels, staggered Continental ExtremeContact DW (225/50/16 front & 205/55/16 rear), Morimoto/Xtreme/Lamin-x HID 5,000K headlights & 4,300K fog lights, OEM LED tail lights, OEM leather seats, OEM JDM leather armrest, Eneos 5W-20, Amsoil 75W-90 GL-4, ATE Super Blue
wildfrisco is offline
post #13 of 30 (permalink) Old 06-29-2009, 04:20 AM
[quote author=WildFrisco link=topic=148367.msg3201692#msg3201692 date=1246215988]
Did you get a printout of your current specs any of the times they said it was within spec? The factory specs are a huge range, especially for toe, and you could be having lots of tire wear issues even if your rear toe is "within spec" that can still be easily solved by a good alignment.
cali_axela is offline
post #14 of 30 (permalink) Old 07-01-2009, 03:53 AM
wildfrisco's Avatar
[quote author=cali_axela link=topic=148367.msg3202468#msg3202468 date=1246260042]
Yes I did. Maybe I'll post it up and someone can glance at it real quick.
post #15 of 30 (permalink) Old 07-01-2009, 09:01 PM Thread Starter
I have an 07 as well, and i'm right at 63k miles. Did the oem set wear funny? because my owm set wore fine, and every set of tires after that wear like shit. Maybe the pothole was just coincidence... but maybe not. It's a pain, sometimes I feel like trading in for something that will wear correctly.
wolph69 is offline
post #16 of 30 (permalink) Old 07-01-2009, 09:39 PM
john_in_the_lbc's Avatar
i'd have an expert inspect the shocks before getting rid of the car.
alignment perfect, new tires...next likely suspect = shocks.
also, maybe the tires were shit too. i would not buy either brand although you didn't specify what tires.
i heard some Potenzas suck ass on treadwear.
My car thread
john_in_the_lbc is offline
post #17 of 30 (permalink) Old 07-02-2009, 12:55 PM
Send a message via AIM to Trubopower
You don't want the toe 0'd out, thats actually probably whats causing the wear. On a FWD car you want the front wheels slightly toe'd out because as the car pulls forward it pulls the front wheels in and they goto 0 naturally, then the opposite for the rear, you want it toe'd in slightly because the rear wheels are unpowered and get dragged along they toe out naturally, so by having them at 0 then they are spreading, which will wear the inner ege of the tires in a scalloped manor.
Trubopower is offline
post #18 of 30 (permalink) Old 07-02-2009, 01:00 PM
Yeah, definitely have your shocks/struts checked out. My tires are cupping too and that is the cause.
- 2008 Mazda3s 5-door Grand Touring in Galaxy Grey Mica (Racing Beat Springs, Koni Sport dampers, Progress Rear Sway bar, Fujita F5 CAI, Drilled rotors from Brake Performance.com, Optima Yellow Top battery, CX-7 "Shorty" antenna, Interior LED lighting kit from dabears2k, Luminics JDM Yellow 2500K fog lights, Phillips Ultinon 6000K HID's, JL Audio 12w6v2 powered by Alpine PDX 1.600 amp)
- 2003 Millennium Yellow Chevrolet Corvette Z06 - Summer DD.
.JJ. is offline
post #19 of 30 (permalink) Old 07-02-2009, 01:11 PM
Send a message via AIM to grumpyjap Send a message via MSN to grumpyjap
wheel bearing going bad can also cause the cupping
grumpyjap is offline
post #20 of 30 (permalink) Old 07-02-2009, 01:30 PM
Moderator of donks
halo0's Avatar
can someone post a pic of a cupped tire?
halo0 is offline
