clunk/rattle in rear end over bumps - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 31 (permalink) Old 04-24-2008, 10:18 AM Thread Starter
My 2005 with 50k has had this noise for probably 10-20k now.
When going over pot holes or sharp bumps or speed bumps, it makes this loud clunk/rattle like something big is loose in the back end.
I removed all items from the trunk and checked the spare area and everything is tight.
I took it to the dealer and they said everything is tight.
I saw several threads on this but no answers yet.
Anyone find a solution? Anyone having the same issue?
Thanks.
bdgood is offline
post #2 of 31 (permalink) Old 04-24-2008, 10:36 AM
Send a message via AIM to cromus
Re: clunk/rattle in rear end over bumps
let me find the threads for you
cromus is offline
post #3 of 31 (permalink) Old 04-24-2008, 10:38 AM
http://www.mazda3forums.com/index.php?topic=94327.0
http://www.mazda3forums.com/index.php?topic=91682.0
http://www.mazda3forums.com/index.php?topic=75673.0
and the answer is
loose endlink
cromus is offline
post #4 of 31 (permalink) Old 04-27-2008, 03:31 PM
Is this something that can easily be fixed by tightening up the bolt? Or do parts needs to be replaced?
cwb27 is offline
post #5 of 31 (permalink) Old 04-27-2008, 03:49 PM
Send a message via MSN to jreeves_86
if its like my prob. even after the bolts are tight you still get the sound
jreeves_86 is offline
post #6 of 31 (permalink) Old 04-29-2008, 05:10 PM
Send a message via AIM to jalweber
I get this same sound at around 40k miles... loose endlink you say?
Many people have gotten similar sounds from blown out shocks as well... either way i'm planning on replacing my whole front and rear suspension
Anyone have a definitive answer on this?
**Image removed. Please read forum rules regarding signature size.
'05 Mazda 3s HB :: AEM CAI :: Magnaflow 2.5" cat-back :: Vibrant Strut Bar :: TWM STS
2 10" Alpine Type-E Subs :: Alpine 500W Mono Amp
jalweber is offline
post #7 of 31 (permalink) Old 04-29-2008, 07:16 PM
I have the same problem. Its the endlinks for the swaybar. The nuts keep loosening up for some reason. Super frustrating. I wrench them fucking tight as can be, and the sound disappears. About a week later the sound is back and they are loose again.
lg paul is offline
post #8 of 31 (permalink) Old 04-29-2008, 08:19 PM
hmm, well i'll check it this weekend and find out if its the same on mine
jalweber is offline
post #9 of 31 (permalink) Old 10-17-2011, 04:50 PM
One way to fix the bolts from coming loose is to put washers between them and the endlinks. I use to have a gocart with a roll cage and those bolts use to get loose all hte time so i finally put washers inbetween the nut and the cage and it never got loose again. I think this might work the same. I'm gonna try it as i have the noise as well.
Low, Fog KWD 35W 6000K, High KWD 55W 6000K , OEM Navigation System + Rearview Camera, LED Dome, Map, Trunk, Glove, License, Simota CF SRI, Angel Eyes, Evotion Condensor, RX8 Wheels, SS Brake Lines (Red), CX7 Stubby, Eibach Prokit, Eibach Camber, Hawk HPS Brake Pads, Tinted Windows, OEM Spoiler
joel1618 is offline
post #10 of 31 (permalink) Old 10-17-2011, 07:02 PM
Mine had a really annoying rattle in the back after I installed Koni Yellows (shocks).
I don't own a torque wrench so I can't give you good numbers, but I tightened the ever living crap out of the lower mounting bolts and it fixed it. The shocks were moving and rattling on the bolts on the lower control arms.
-Eric
rccardude04 is offline
