ALL AVAILABLE SUSPENSION Components - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 194 (permalink) Old 03-20-2008, 12:07 AM Thread Starter
Coilovers:
H&R
Mazda 3 04+
1.2 - 2.5/0.75 - 2.0
Front & Rear Progressive rate
Non-Adjustable Monotube Inverted shocks
Part # 29197-3
Mazdaspeed3
Part # 29197-6
KW
Mazda 3 04+ Variant 2
30-60/30-60mm
1.2-2.3/1.2-2.3in
DSpring Rates Front= 340/Rear=P
Part No: 15275006
Mazdaspeed3 Variant 1,2,3
Drop .8-2.0in Front & Rear
Spring Rate Front 400/Rear Progressive
Part Numbers:
Variant 1: 10275010
Variant 2: 15275010
Variant 3: 32575010
K-Sport
Rally Spec AR Damper System
Compression/Rebound adjustable
Pillow ball top mount w/ adjustable camber (not available for some models)
Monotube
36-way adjustable dampening
Part # CMZ01-AR
Spring Rates – Not given
1600$
Front Mount P/U
Rear Mount ATM
Kontrol Pro Damper System
36 levels of adjustable dampening
Monotube
03-+
Part # - CMZ01-KP
$1,300.00
9/504
5/280
Front Mount P/U
Rear Mount ATM
GT Pro Damper System
Inverted steel shock absorber for durability
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube
03-+
Part # - CMZ01-GT
$1,760.00
9/504
5/280
Front Mount P/U
Rear Mount ATM
Version RR Damper System
• Aggressive valving and spring rates
• Reinforced internals
• Race applications only
• 36-way adjustable dampening
• Compression/Rebound adjustable
Monotube
CMZ01-RR
Bilstein
B16 'PSS9'
Product code: GM5-C126
30-60mm Front and Rear
9-Way Damping Adjustable
allows for adjustable damping in both the compression and rebound cycles
B14 'PSS'
Product # HE5-C122
30mm and 60mm Front and Rear
Monotube inverted technology
JiC
FLT-TAR
Mazda 3 04+
Front & Rear Springs: Linear
Spring Rate: Unknown
Gas Filled Shocks
Product # BK3PFLTA2
BC
Racing Coilovers
Mazda 3 04 +
Front Spring Rate 330
Rear Spring Rate 220
Front & Rear Upper Pillow Ball Mount included
30 Levels of Adjustable Damping
Monotube Shock Design
Stance
Mazda3 04+
Front Rate 6k
Rear Rate 5k
Part # None Listed
Linear Springs
Camber adjustable pillow mount
Rebound adjustable
D2
Mazda 3 04+
Front Rate 9.8kg/mm
Rear Rate 4.6kg/mm
Part # D2-M01
Linear
Dampening Adjustable
Megan Racing
Spring Rate: 8kg Front 10kg Rear
32 Way adjustable valving on front and rear shocks
Part # MR-CDK-M303
Autoexe
Drop: Adjustable
Spring Rate:
Spring Type:
Dampening Adjustable:
Tein
Tein Basic
Drop: Front -.9 to -2.3 , Rear -.4 to -1.6
Spring Rate: 336/392
Spring Type: Linear
Dampening Adjustable: No
SuperStreet
Spring Type: Linear
Dampening Adjustable: Yes
EDFC: Available, part # EDKU1-12120
Shock & Spring Combo (Non-Coilover)
Bilstein
B12 Suspension Kits non coilovers
Product code: SE5-B079
• Lowers Front 30mm
• Lowers Rear 30mm
Koni
Sport Suspension 1130
Spring by Vogtland
Shock by Koni Yellow
external rebound adjustment
Koni FSD Suspension
Koni FSD shock
Eibach Pro-Kit Spring
Springs & Shocks
OEM
(F) 150 (R) 130
Eibach
Mazda 3 04+
Pro-Kit:
Front 1.2 Rear 1.2
Spring Rate: (F) 160 (R) 171
Spring Type: Linear, Single Rate
Sportline Kit:
Front 1.8 Rear 1.8
Spring Rate: (F) 97 - 280 (R) 114 - 303
Spring Type: Progressive, Dual Rate
H&R
Mazda 3 04+
Sport Spring 1.3Front Rear1.2
Part #51643
Mazdaspeed 3 07+
Part #51643-2
K-Sport
Mazda 3 04+
Drop – Front 1.3" Rear 1.3"
Part #LSMZ01
Progressive Rate Front & Rear
Vogtland
Lowering Springs
1.6in drop
40mm
Part #958028
Autoexe
Drop: 1.9F 1.5R (not exact; based on pictures and comments)
Spring Rate:
Spring Type:
BG Suspensions
Sport Spring
Drop: 1.4 Front & Rear
Spring Rate:
Spring Type:
Part # 50.1.052
Canuck Motorsports
Drop: 1.75 Front & Rear
Spring Rate: (F) 170 (R) 160
Spring Type:
Goldline
Drop: 1.5 Front & Rear
Spring Rate:
Spring Type:
Part #GPS-1104
Mazdaspeed
Drop: 1.2 Front & Rear
Spring Rate:
Spring Type:
Postert
Drop: 1.37 front and rear
Spring Rate:
Spring Type:
Intrax
Drop: 1.5& Front & Rear
Spring Rate:
Spring Type:
Part # 45.1.026
Progress
Drop: 1.3 Front & Rear
Spring Rate: (F) 190 (R) 170
Part #40.1125
Road Magnet
Front 1.25; Rear 1.25 or Front 1.75 Rear 1.75
Spring Rate: (F) 310 (R) 360
Skunk2
Drop: 1.5 front 1.3 rear
Spring Rate: 142-208/116-159
Tanabe
Drop: 1.5 front 1.1 rear
Spring Rate:
Spring Type:
Tein
H-Tech
Drop: 1.4 front 0.9 rear
Spring Rate: (F) 150 (R) 220
Spring Type:
S-Tech
Drop: 2.0" front 1.5" rear
Spring Rate: (F) 160 (R) 240
Spring Type:
Sprint
Spring Rate:
Spring Type:
Part #7530
Megan Racing
Springs Rate: (F) 250 (R) 230
Spring Type:
Racing Beat
Drop: 0.6 Front 0.5 Rear
Spring Rate: (F) 151 (R) 143
Spring Type:
Sway Bars
H&R
24mm Adjustable Front (Solid)
Part #70643
26mm Non-Adjustable Rear (Solid)
Part #71643
Urethane/Teflon composite bushings featuring a molded-in fabric-like material that requires no maintenance H&R Sway Bars are powder coated for long lasting performance, quality and beauty.intenance or lubrication, and eliminates squeaking
Eibach
26mm Front (Solid)
Part #5545.310
26mm Rear (Solid)
Part #5545.312
Part # 5545.320 (as pair)
Hotchkis
29mm Front (Hollow)
32mm Adjustable Rear (Hollow)
Part # 22436
95% stiffer than the stock sway bar with a rate of 1625 lbs/in
140% stiffer than the stock sway bar with a rate of 2030 lbs/in
Easy to lubricate polyurethane bushings and heavy duty brackets with zerk fittings included
Progress
22mm Adjustable Rear (Solid)
62.1125
Mazda 3 Stock Bars
Front Bar: 21mm (Solid)
Rear Bar: 20mm (Solid)
Mazdaspeed (Specific for Mazda 3)
21mm Rear (Solid)
Mazdaspeed 3 Stock
Front Bar: 26mm (Solid)
Rear Bar: 26mm (Solid)
Mazdaspeed 3 Aftermarket
F2
Rear Bar: 25 mm (Solid)
Whiteline
22mm rear
22mm front
Auto-exe
Cobb Tuning
Front
1 1/8” Outer Diameter
35% Stiffer than Stock
Rear
1/14” Outer Diameter
50% and 90% Stiffer than Stock (adjustable)
Racing Beat
27mm Rear Adjustable (Hollow)
28.5mm Front
Camber Kits
Eibach / SPC
Part #52.1125
+5.0° to -1.5° of adjustment
Megan Racing
Part # MR-6457
Features Hardened Bushings
Camber Adj Range Not Listed
Mazdaspeed
Non-Adjustable -1.25?
Dominant Engineering
Adjustable +1 to -9
Corksport
Adjustable +5 to -5
Heim joint / metal on metal rod end.
Braces & Chassis Reinforcement
Mazdaspeed
Front Strut Tower Bar
Part # 143-018-712
GTSpec
Front Strut Brace GTS-SUS-1124
Rear Link Reinforcment Panel GTS-SUS-1127
Rear V-Brace GTS-SUS-1128
4 Points Ladder Brace GTS-SUS-1135
Front Lower Tie Brace GTS-SUS-1125 (3 Only Not Mazspeed3) Member noted that 2.0 Auto only
Rear Lower Tie Brace GTS-SUS-1126
4 Point Brace GTS-SUS-1190
Mid Chasis Brace GTS-SUS-1158 Not app for PZEV
Trunk Reinforcement Brace GTS-SUS-1129
Ultraracing
Front Strut Brace UR-TW2-109 Req modification to fit properly
Front Lower Bar, Front Member Brace UR-LA4-148
Rear Lower Bar, Rear Member Brace UR-RL2-124
Mazdaspeed
Strut Tower Brace
Vibrant
Strut Tower Bar v1 Does not fit sedan models
Endlinks
AWR
Whiteline
Powergrid
Tripoint
Corksport
Reference
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
*Angel-Of-Darknes* is offline
post #2 of 194 (permalink) Old 03-20-2008, 12:09 AM Thread Starter
Re: (List) ALL AVAILABLE SUSPENSION Compnents
please stinky and delete the old thread because no one updates the damn thing..
yes I understand their is alot of info still missing but I am posting the preliminary list now. So that we can build on it as a forum.
post #3 of 194 (permalink) Old 03-20-2008, 01:01 AM
Thank you for posting up a updated version of the suspension thread.
Don't forget strut bars
island warrior is offline
post #4 of 194 (permalink) Old 03-20-2008, 01:08 AM Thread Starter
i will stay up to date with it for as long as I am a member and the list will consistently reflect that result. I will in the future as parts become available add more things to it like strut bars and front end camber caster adjustment..traction bats which i am waiting for a release date as well and any other components related to the enhancement of are suspensions, Angel.
post #5 of 194 (permalink) Old 03-20-2008, 10:22 AM
Send a message via AIM to boosthead
Megan Racing
-Lower 2" front and 1.9" rear
-Springs rate - 250 Front and 230 Rear
boosthead is offline
post #6 of 194 (permalink) Old 03-20-2008, 11:57 AM
Send a message via AIM to antricparticle
Springs
Sprint
Part Number: 7530
Front Drop: 1.75"
Rear Drop: 1.75"
antricparticle is offline
post #7 of 194 (permalink) Old 03-20-2008, 03:05 PM Thread Starter
thankyou for the add everyone. keeping it updated.
post #8 of 194 (permalink) Old 03-21-2008, 10:27 AM
[quote author=*Angel-Of-Darknes* link=topic=106175.msg2165476#msg2165476 date=1205986022]
Mazdaspeed 3 Stock
Front Bar: 21mm
Rear Bar: 20mm
21mm Rear
Incorrect according to this thread: http://www.mazda3forums.com/index.ph...829#msg2018829
Edit: Also verified by this thread: http://www.mazda3forums.com/index.php?topic=89840.0
If it wasn't for a search, and if I had just relied on the sticky, I would have missed out on some cheap MS3 stock bars for sale thinking they weren't much of an upgrade. Proof that this list needed to be done.
They are 26mm. Stock Mazdaspeed3 bars and Mazdaspeed Accessory bars are the same. Please correct me if I'm wrong.
post #9 of 194 (permalink) Old 03-21-2008, 11:41 AM Thread Starter
oops thats my fault. those bar sizes are supposed to be under the mazda 3 stock bar sizes not MS3 good eye and thankyou
post #10 of 194 (permalink) Old 03-23-2008, 12:37 AM
Thank you A.O.D.!!!!
Mezda3 is offline
WTB: STOCK Mazda 3 suspension components davidlee89 Want to Buy | M3F 1 08-13-2010 05:46 PM
Need help choosing suspension components :-) Amodarus Suspension / Brakes 2 05-02-2009 11:22 AM
Tanabe suspension components cc Suspension / Brakes 1 02-24-2005 11:23 AM
