2006 Mazda 3 Shifting Problems - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 14 (permalink) Old 05-21-2012, 03:18 PM Thread Starter
Send a message via MSN to seus7
I have a 2006 Mazda 3 2.3. Shifting into every gear works fine, except 3rd. Most of the time when I try to shift into 3rd, it will either just straight up grind and not go into gear at all, or go into gear and then get pushed back out. If I hold the shifter hard enough, it will make a loud bang, but stay in gear. Any ideas what could cause this to happen? The clutch isn't over a year old, and it hasn't been driven hard since it's replacement. Linkage maybe?
2006 Mazda 3 GT (current)
1994 Mazda MX-6 (sold)
2001 Saturn L100 (write off)
seus7 is offline
post #2 of 14 (permalink) Old 05-21-2012, 06:18 PM
Re: 2006 Mazda 3 Shifting Problems
I just posted about the same thing yesterday, I have an 07. There a number of things that could cause it, but there are a few that are the usual suspects. I just replaced my Rear Motor Mount with a CP-E 75 durometer, it's magical. It stiffens the whole car up and makes the gearbox much more fluid. It did help quite a bit, but I'm still not out of the woods. However, I've been running Royal Purple 75w90 GL-5 gear oil and it was suggested to me to use Redline Mt-90 GL-4 because of our transmission's synchros. The GL-5 doesn't play nice with them.
More times than not, people will tell you it's the motor mount and for the most part it helps a great deal. I'll let you know if I have any luck with the new gear oil.
ledzippel is offline
post #3 of 14 (permalink) Old 05-22-2012, 01:28 PM Thread Starter
Thanks for the info. My motor and clutch were replaced a while ago, so I don't know what gear oil is in it. I'll defiantly take a look at the rear motor mount too.
Again, thank you.
seus7 is offline
post #4 of 14 (permalink) Old 05-23-2012, 05:32 PM Thread Starter
I went to two different shops and saw two different mechanics. They both came up with the same answer, that its the synchros, and they're very, very bad. Looks like I'll be driving around without 3rd for a while.
seus7 is offline
post #5 of 14 (permalink) Old 05-24-2012, 09:19 PM
So I just swapped out the GL-5 75w90 Royal Purple gear oil for GL-4 MT 75w90, no more 3rd gear grinding! I'm dumbfounded. I went for a quick 5 minute drive and continually shifted from 2nd to 3rd and no issues. I drive just short of 60 miles to and from work (120 round trip), so I'll give you a better review/update tomorrow after a longer driving stint. Initial results are promising! You may want to grab some. I bought some (3 - 1 Quart)on Amazon for $44, you may want to give it a try before spending more on new synchros.
post #6 of 14 (permalink) Old 05-30-2012, 04:14 PM Thread Starter
I'll give it a shot!
seus7 is offline
post #7 of 14 (permalink) Old 05-31-2012, 08:34 AM
Awesome. Here's an update: Have driven over 500 miles with the GL-4 Redline MT 90 and I can say that 3rd gear is now perfect. Shifting through the gear box is like butter. It's really pretty amazing. I'm considering moving to Redline 5w20 as well.
post #8 of 14 (permalink) Old 06-01-2012, 11:28 AM
GL4 - MT90 is the way to go as well as the 5W20 Redline. I use both of those oils in the Mazda 3 race car and work very well.
- Ali
offlineracing is offline
post #9 of 14 (permalink) Old 06-04-2012, 04:23 PM
I'm glad you found a soultion to the problem. I just wanted to add that Mazda put out a TSB about this 3rd gear problem & they will apparently fix it (replace synchro/3rd gear, etc.) if your vehicle is still under warranty.
lyongrl is offline
post #10 of 14 (permalink) Old 06-05-2012, 08:35 PM
mazdaboy2.3's Avatar
I just put Mobil 1 in my car. Is that ok?
I tried Autocross once, and won....I think i'm gonna like this.
Build thread:
mazdaboy2.3 is offline
