fuel pump replacement how to? - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 17 (permalink) Old 10-30-2011, 08:54 PM Thread Starter
does anyone have a how to on the fuel pump or any pointers before i start tackling this task? thanks
lo1antman is offline
post #2 of 17 (permalink) Old 10-31-2011, 10:52 PM
Re: fuel pump replacement how to?
Get one from the junkyard. I have looked around and parts stores only sell the basket as a single unit not just the pump. Depending on the year of car and emissions protocol could range from $300-$450
also getting to the fuel tank isn't hard jsut make sure when you go to unlock the pump from the tank push down otherwise the child lock will kick in and you will just free spin the pump in place.
pinkcheese is offline
post #3 of 17 (permalink) Old 11-01-2011, 02:17 AM Thread Starter
ok thanks for the pointers and also one more thing, i have to drop the fuel tank to get to the fuel pump right?
post #4 of 17 (permalink) Old 11-01-2011, 11:08 AM
yes
post #5 of 17 (permalink) Old 11-01-2011, 11:47 AM
To make the job easier, have the tank as empty as possible, otherwise your gonna make a mess.
There are two different styles of fuel pump depending on if you have a plastic tank or a metal one. The metal one has a little slide ring that only requires a screw driver and a hammer to remove.
Make sure you pull the rear seat cushion up and disconnect the fuel pump connector.
ekanddsm is offline
post #6 of 17 (permalink) Old 12-18-2011, 12:29 AM
For a step by step procedure on how to replace the fuel pump, go to: http://www.4shared.com/folder/tF1dpg9H/_online.html and download the PDF file. I put together this doc when I replaced mine.
Hope this helps.
Jolo is offline
post #7 of 17 (permalink) Old 12-21-2011, 03:12 PM
Send a message via AIM to Eighty8
Do the regular 3's have a CDFP as well? Or just a fuel pump in the tank?
2007 True Red Mazdaspeed 3
Fujita CAI / Cobb AP / Cobb TIP / Cobb DP / Autotech HPFP Internals / Turbosmart Dual Port / Sure SSP / Sure SSB / Sure RMM / JBR EGR BO / Spin-On Oil Filter / Whiteline BSC / Whiteline Castor Kit / Kumho Ecsta SPT
Eighty8 is offline
post #8 of 17 (permalink) Old 12-21-2011, 04:37 PM
Moderate your face
dugger_8's Avatar
Just a pump in the tank.
dugger_8 is offline
post #9 of 17 (permalink) Old 05-01-2014, 05:28 PM
eljean's Avatar
Originally Posted by pinkcheese View Post
yes
Do you have to lower it even if you're replacing the entire fuel pump assembly?
eljean is offline
post #10 of 17 (permalink) Old 05-01-2014, 06:31 PM
okellyr's Avatar
Yes, the assembly can only be accessed by dropping the tank
Boosted baby....
BOOSTED
okellyr is offline
