Airbag control module replacement - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 9 (permalink) Old 11-27-2009, 11:28 PM Thread Starter
I bought a 2005 Mazda 3 and the drivers side airbag was deployed. I replaced the airbag and drivers side seat belt but the air bag light is still on solid. I put it on a scanner and I am getting codes B2234 and B1934.
B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib
B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2
Any ideas, I was thinking that the Air bag control module needs to be replaced. I have one but I am not sure where this module is located. I have read to replace it you need to disconnect the battery and replace but I cannot find a picture or a description of the location to actually replace it.
PLease Help!
THanks,Dave
dmackinnon is offline
post #2 of 9 (permalink) Old 11-27-2009, 11:35 PM
Re: Airbag control module replacement
its located in the center console near the base of the hand brake.
edit: take a look at the link. it also says that the crash zone sensor must be replaced when the airbags are deployed.
http://michaelstaines.com/Mazda/esic...057030W01.html
Oricle is offline
post #3 of 9 (permalink) Old 07-06-2011, 04:55 PM
Did you ever get this fixed? I think I'm going through the same problem. I just ordered a new airbag control module from myairbags.com. I just hope it works when I install it. I don't want to go back to the dealer and spend time over there getting it coded.
'04 mz3 l painted calipers l smoked taillights l tints (30f 20r) l open mouth grille l LED map/dome lights l window vents l oem all weather floor mats l neo ipod adapter l 6k HIDs l front rally amour mud flaps
breezy3 is offline
post #4 of 9 (permalink) Old 07-07-2011, 04:49 AM
You do not need to waste money replacing the Airbag module. You need to reset it. Do not go ask in the Dealer as they will tell you that this is impossible. All they want is your money.
The Airbag module is located underneath the center console. It hilariously easy to take it off. Whatever you do you always have the battery disconnected! Do not know how to stress that enough! Make sure that you have connected the Crash Sensor in the front of the vehicle before dealing with the Airbag Module. Airbags must be replaced! If not, even though the Airbag Module has been reset your light will not disappear.
FS:Rays MS-T II Rims 5x114.3 with Michelin Pilot Alpin PA3 225/40/18
Nakadah is offline
post #5 of 9 (permalink) Old 11-27-2011, 12:54 PM
I am in the body shop buissness and I have repaired many cars with this problem. When ever a airbag is deployed the crash module must be replaced or reset. The module stores a code on impact and it is a hard code so after you replace the airbags it still shows hard code impact. I have had to never replace the front sensor unless it had taken a direct hit. There are some people on e-bay that reset these modules and if you would like someone I use e-mail me off forum. Also be real careful when you plug in the new airbags. Make sure they are connected, with the plastic ends being not melted from the deloyed bags. If they are melted then get new ends and replace them. You can get the ends on e-bay or buy a used/new clock spring. I have never had one that didn't work after I repaired it. Good luck.
kglow is offline
post #6 of 9 (permalink) Old 01-23-2016, 12:52 PM
Airbag Control Module Programming
I have a 2012 Mazda 3 and am having a mechanic replace the Airbag Control Module for us. He called yesterday and said he couldn't get it programmed. Do these need programming? He said he was calling his software provider and would let us know Monday.
Let me know and thanks!
mmitsch is offline
post #7 of 9 (permalink) Old 09-16-2016, 04:50 AM
safetyrestore's Avatar
Airbag control module programmer will provide you best solution for your airbag issue. It needs more and more attention to repair airbag modules and only professional programmer can do this task.
We also provide the best seat belts and airbag control module programming services in Westfield, you may contact us too.
Thanks
safetyrestore is offline
post #8 of 9 (permalink) Old 09-16-2016, 06:08 AM
Great products for complete inner and outer protection of your favorite vehicle:
Luxxio ? Car Detail | Products
milos.ljubic is offline
post #9 of 9 (permalink) Old 01-03-2017, 07:50 AM
Thanks
Hi, 2012 Mazda 3... my girlfriend swears she didn't hit anything, and that the driver side overhead and seat airbags went off for absolutely no reason. The dealership allegedly brought out an engineer to look at the code and said there was an impact but there is nothing on the body of the vehicle with the exception of a hole in the front wheel well by the steering wheel, and some rash where I hit a pot hole a few months ago and pulled the bumper guard loose. I pinned it back up... There is no recall and they are insisting we pay for it. I don't know who to believe, but I'm inclined to believe my girl because of the lack of physical evidence with the body. Are these thing that sensitive that they would pop from a pot hole or rock sized object going up the wheel well? Does the computer ever lie? Do the engineers?
Cmauldin87 is offline
