radiator drain plug problem - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 2 (permalink) Old 04-20-2017, 08:19 PM Thread Starter
MorrisGray's Avatar
I wanted to change coolant so I took my plastic radiator drain plug out and drained the old coolant but now it does not just screw back in and I have no idea why not?!?]
Dorman 61138 is part number that looks identical to what I took out but it is as if there are no threads in the radiator hole to screw this back in. I am at a total loss of understanding how I can unscrew this part and it looks new with good plastic threads undamaged and yet it will not screw back into the same hole it came out of. There has to be a secret or something I just can not comprehend.
Any help would be appreciated. I could not figure out how to post a picture from my chromebook to show you the drain plug I took out.
MorrisGray is offline
post #2 of 2 (permalink) Old 04-21-2017, 09:32 AM
I'm sure you've probably figured it out by now, but if not, here's a guess (I haven't actually removed this plug myself). Have you tried giving it a bit of extra push, before starting to thread it in? If they built a one-way taper into the rad port, then the plug may need to be pushed past the taper and 'popped' in.
2011 3i 2.0 A/T 93K miles (daughter's ride which I maintain)
m3iguy is offline
  Mazda3 Forums : The #1 Mazda 3 Forum > Mazda3 General Discussion > Mazda3 (Axela) > Technical Information, FAQ's, How-To's
Door lock problem The Veg Technical Information, FAQ's, How-To's 2 04-06-2017 10:09 AM
Mazda 3 Hatch Problem (2010) Kalaalit_Nunaat Mazda3 (Axela) 0 02-20-2017 06:15 PM
Very complex problem - Anti-theft car won't start Merlin123 Mazda3 (Axela) 3 02-17-2017 08:18 AM
Worst Winter Problem ever.... 08fusiongirl Introductions 4 01-27-2017 03:47 PM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto RockAuto 0 01-12-2017 03:10 PM
