Special Thanks To Aminzer and Cain who provided 99% of this information to me.
This Information Pertains to Swapping from an '05 with a 5 speed G35M-R, to the speed3's A26M-R.
Your Parts May Vary.
Non-ABS cars and Automatics will not have a speedo if you do this swap. This is due to the fact that non-abs and automatic cars use a speed sensor on the transmission. Cars with ABS use the ABS sensors to drive the speedo.
This parts list pertains to my '05 MZ3S with the 5 Speed Manual, your parts may vary.
Transmission:
Stock - G35m-R
MS3 - A26m-R
Obviously Need The Transmission.
Stock Used Price - $400-$1000 depending on mileage
MS3 Used Price - $1000-1500 depending on mileage
I Bought One For $1281. From An '07 MS3, 40k Miles, 100 Day Parts Warranty.
Transmission Sensors:
Stock - Neutral + Reverse Switch (Optional Speed Sensor)
MS3 - Neutral + Reverse Switch
Sensors Are Compatible For All Manuals With ABS. Speedo Uses ABS Sensors.
If you have a manual car with ABS your speedo will still work, if not then you are SOL.
Axle Diameter As Measured At The Hubs:
Stock - 1.083in (measured on top of splines)
Stock - 1.063 (measured between the splines)
MS3 - 1.125in (measured on top of splines)
MS3 - 1.083in (measured between the splines)
Hub Sizes Are Different. Need To Replace Hubs.
Stock Used Price - $50-125 ea.
MS3 Used Price - $40-125 ea.
Axle Diameter As Measured At The Differential:
Stock - (measured at top of splines)
Stock - (measured between the splines)
MS3 - (measured at top of splines)
MS3 - (measured between the splines)
Axle Sizes Are Different. Need To Replace Axles.
Stock Used Price - $100-200 for a set
MS3 Used Price - $300-400 for a set
Input Shaft Diameter:
Stock - 22 teeth
MS3 - ? teeth
Input Shaft Sizes Are Different. Need to Replace Clutch.
Flywheel Depth:
Stock - (depth)
Stock - (diameter)
MS3 - (depth)
MS3 - (diameter)
Flywheels Are Different Depths. MS3 Flywheel Is Dual Mass And Much Thicker. Need To Replace Flywheel.
Slave Cylinder Configuration:
Stock -
MS3 -
Slave Cylinders Are Compatible.
Slave Cylinders Have Different Piston Diameters. This Greatly Changes Pedal Effort. MS3 Slave Strongly Recommended.
Shifter Configuration:
Stock -
MS3 -
Shifters And Cables Are Different. Need To Replace Shift Assembly.
Gear Ratios:
Mazda 3:
1 3.307
2 1.842
3 1.310
4 0.970
5 0.755
R 3.166
Final 4.105
Mazdaspeed 3:
1 3.538
2 2.238
3 1.535
4 1.171
5 1.085
6 0.853
R 3.831
Final
1-4 3.941
5-6 3.350
http://img40.imageshack.us/gal.php?g=img0407ha.jpg
Transmission:
Stock - G35m-R
MS3 - A26m-R
Stock - 22 teeth
MS3 - ? teeth
Flywheel Depth:
Stock - (depth)
Stock - (diameter)
MS3 - (depth)
MS3 - (diameter)
Stock -
MS3 -
Stock -
MS3 -
Gear Ratios:
Mazda 3:
1 3.307
2 1.842
3 1.310
4 0.970
5 0.755
R 3.166
Final 4.105
Mazdaspeed 3:
1 3.538
2 2.238
3 1.535
4 1.171
5 1.085
6 0.853
R 3.831
Final
1-4 3.941
5-6 3.350
