Vibration at 60mph impossible to fix! - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 30 (permalink) Old 06-10-2010, 01:54 AM Thread Starter
dL.
I'm surprised I still haven't given up on fixing my vibration issue at 60mph highway speed.
These are ALL the things I've done:
- Front rotors replaced
- Tried 2 sets of brand new tires
- Balanced all 4 wheels, WITH HUNTER ROADFORCE
- Alignment completed
- With or without spacers, the car still vibrates
- With or without plastic or metal hubcentric rings, the car still vibrates
- Wheels are checked by wheel shop and is not bent nor damaged
- Wheel bore is not damaged
- CV boot checked and is fine
- Inspected by Mazda
Here are some interesting facts:
- Another car shop put OEM Mazda 3 wheels with brand new aftermarket Kumho tires and there are still vibration.
- Last time when Mazda inspected, they tried 4 OEM wheels with brand new aftermarket Toyo tires. 2 of them caused vibrations, 2 did not ON ONE PARTICULAR ROAD. Read below.
- I noticed that the car vibrates whenever it decides to. Why? Well I've tried driving on the exact same road, at the same speed and one time it vibrated a lot and the other time it did not vibrate at all.
Here are the possible things that I may still try. Please throw in as many suggestions as possible:
- Rack and pinion. One technician suggested I get Mazda to inspect and tighten my rack and pinion a little bit to see if that may fix the issue.
- The shocks are done? Last time I brought it to a shop for alignment recently, they did mention my front left shocks and springs is a little bit damaged, though not to the point that it needs a replacement immediately. BUT, could that cause the vibration?
- Control arm
- Steering tie rod
- Steering wheel?! It doesn't seem that loose to me.
I got a question for all. My steering wheel wants to instantly drive right even after an alignment on the highway. What could that possibly be?
I have a 24k type service coming up (72k on odo) and the reason why I posted this is to get as many suggestions as possible for diagnosis. Last time when I brought it to Mazda, I just told them I have vibration and they spent 3 hours trying to balance the wheels and stuff which I have already done with 3 separate shops and have not fixed the issue. IMO, they fluked the Toyo tires in that one situation and just sent me away. SO this time, I want to actually have a list of things I want the dealership to check during my big service and see what they think instead of blindly telling them to inspect for vibration.
3 months and counting, but I know I will find the solution one day. Please help me figure out the impossible. Thanks in advance!
dL
dL. is offline
post #2 of 30 (permalink) Old 06-10-2010, 01:55 AM Thread Starter
dL.
Re: Vibration at 60mph impossible to fix!
dL. is offline
post #3 of 30 (permalink) Old 06-10-2010, 02:53 AM
you sure it has nothing to do with engine rpms? I guess that doesn't explain the steering wheel thing
after what memorable car event did this occur?
itstillruns is offline
post #4 of 30 (permalink) Old 06-11-2010, 05:34 PM
stupid8000's Avatar
spring or shock looks damaged? that right there will cause some issues with the wheel not staying were it should.
Rebuild log coming soon
stupid8000 is offline
post #5 of 30 (permalink) Old 06-11-2010, 05:49 PM
http://www.finishlineperformance.com...01-07-1823.pdf
work to live
tonyzoomzoom is offline
post #6 of 30 (permalink) Old 06-11-2010, 06:00 PM
[quote author=tonyzoomzoom link=topic=174374.msg3693758#msg3693758 date=1276292942]
Yes, this. Almost guaranteed given everything else you've tried not working. A busted engine mount can definitely cause this issue.
cali_axela is offline
post #7 of 30 (permalink) Old 06-11-2010, 06:26 PM
Send a message via AIM to boosthead
I experienced a similar issue with a busted rear mount. Also check your passenger side mount.
boosthead is offline
post #8 of 30 (permalink) Old 06-14-2010, 08:24 PM Thread Starter
dL.
Thanks a lot Uncle T! I'll bring this up to the service that's coming up.
dL
dL. is offline
post #9 of 30 (permalink) Old 06-14-2010, 09:26 PM
Oops. Re-post of http://www.finishlineperformance.com...01-07-1823.pdf
post #10 of 30 (permalink) Old 06-14-2010, 09:57 PM
You can most certainly check the mounts. But I noticed the only thing you did not mention is the wheel bearings.
Also our car's rear susp is quite advanced as it is a multi-link subframe setup. Body damage or damage to subframe whether the sub frame mounting points etc. could cause steering to 'wander off' on it's own.
Jus my $0.02
1989 Mazda 323 SE 1.6 (5-speed), Sand/Beige/Black(20%)
2007 Mazda3i Touring (5-speed) NON-PZEV , Galaxy Grey Mica/Black/Black(5%)
1991 Nissan 300ZX (5-speed), Stage II+, Diamond Black Pearl/Black/Black(5%)
2004 Nissan Sentra
quikz is offline
