Squeaky clutch - Mazda3 Forums : The #1 Mazda 3 Forum
post #1 of 10 (permalink) Old 10-26-2006, 06:19 PM Thread Starter
Squeaky clutch
I've noticed recently that my clutch pedal is squeaky when I press it and release it. It's gotten better over the last few days but I'm still concerned about it. Is there some kind of grease/oil I can use on it or is this a bigger problem? I'd like to see if it's something I can fix before I hassle with the dealer. Know what I mean?
Mazda3Pride is offline
post #2 of 10 (permalink) Old 10-29-2006, 07:27 AM Thread Starter
Re: Squeaky clutch
No suggestions huh?
post #3 of 10 (permalink) Old 10-29-2006, 03:49 PM
Re: Squeaky clutch
Find the pivot point for the clutch pedal and lube it up with some white lithium grease
MattDeZ is offline
post #4 of 10 (permalink) Old 10-29-2006, 06:35 PM
Send a message via AIM to ViperKillerWannabe
Re: Squeaky clutch
Turn the radio up and forget about it. It's not hurting anything.
2005 Sunlight Silver Metallic 3s
ViperKillerWannabe is offline
post #5 of 10 (permalink) Old 10-29-2006, 06:56 PM
Send a message via AIM to cbogey88
Re: Squeaky clutch
Mine does that too man. It's about annoying when I have someone with me and have the radio down. I'm just gonna tell my dealer to grease it up next visit. They shouldn't charge anything for it.
cbogey88 is offline
post #6 of 10 (permalink) Old 10-29-2006, 07:48 PM
Re: Squeaky clutch
WD-40 did the trick for me but grease would be ideal. I know someone mentioned on another thread that there was some issue with a part of the clutch but I really don't feel like going through the hassle of dropping my car off at the dealership and have them tell me some bs like my aftermarket component speakers are the cause of the squeaking. You gotta get the pivot point and I believe there was also another piece of plastic that i shot cuz that was makin noise too
'05 sunlight silver metallic 3s: leather, abs, sports package, moonroof, 6cd changer.
Eclipse CD8445 HU w/ full steering wheel control, sirius, infinity reference 311a amp w/ perfect 12.1d sub, ported box, rainbow slc 265 components, diamond d3 amp, custom amp rack, superbright white led map and dome lights, sharkfin antenna, aftermarket heated seats, Ark Shortshifter
ak47clown is offline
post #7 of 10 (permalink) Old 10-30-2006, 06:15 AM Thread Starter
Re: Squeaky clutch
Thanks for the heads up guys.
post #8 of 10 (permalink) Old 10-30-2006, 08:49 AM
Re: Squeaky clutch
It was an issue with the clutch master cylinder for me and one or two other memebers. Most other people it is an issue with the clutch pedal assembly or the clutch ignition lockout switch. Try greasing it with some lithium grease. If it is an issue with the clutch master cylinder it is LOUD, you can't drown that out with the radio unless you like listening to it at 20+ volume all the time.
-Matt
azazel1024 is offline
post #9 of 10 (permalink) Old 10-31-2006, 02:04 PM
Re: Squeaky clutch
this happened to me and the dealer changed the clutch assembly for free
sig fixed!
aid03 is offline
post #10 of 10 (permalink) Old 10-31-2006, 02:22 PM
Re: Squeaky clutch
mine comes and goes . My clutch squeaked in my previous car too. It ended up being a leaky clutch slave master cylinder, which had brake fluid/clutch fluid run down my pedal.
2004 black mica 3s w/5-spd
AEM CAI | Vibrant exhaust| advanced timing
mica3speedy is offline
